Wiring Electric Fan without ECM
Old Aug 6, 2014 | 10:58 PM
JrBrein1988's Avatar
Car: 1988 Pontiac Firebird
Engine: LO3 5.0 (305) TBI
I have an 88 Firebird Vin E TBI with the L03 5.0L; however I am swapping over to a new carbed 350 and I understand that the stock electric fan is controlled by the ecm. How will I get the fan to work properly without the ecm? I'm a little confused when it comes to the wiring. Sorry if this is basic question but I'm totally lost. Any help would be appreciated. Thanks.
Old Aug 9, 2014 | 03:25 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Re: Wiring Electric Fan without ECM
If you have a stock, single fan you can get by with a standard 30A fan relay kit. Use your stock coolant temp switch to trigger the relay. If you want, I stock everything from a simple kit like that to a 3 speed resistor harness designed for extremely HO fan(s) setups. If you have your old motor still you'll want to retain the temp switch and connector/pigtail. If not, no worry I stock those parts in stock if needed. PM me if ya want. A basic relay kit is about $25 plus shipping. What you need isn't too complicated to assemble and install.
Old Aug 11, 2014 | 12:21 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Do you have a functioning AC system?
Old Aug 11, 2014 | 09:57 PM
My AC is not functioning at all. I believe the electrical connections are unusable.
Old Aug 11, 2014 | 10:19 PM
Keoman's Avatar
that makes life easier when wiring a fan.
get a relay harness
wire 30 and 85 to battery
86 to fan switch in the cylinder head
87 to fan positive wire
the fan can spin both ways (push or pull air) depending on which wire you hook 87 to. test the fan on the battery before you install the wires for good so you know.
voila, you have a automatic cooling fan setup. easy peezy
Old Aug 11, 2014 | 10:31 PM
Where can i find this fan relay kit at?
Old Aug 11, 2014 | 10:35 PM
Keoman's Avatar
should be able to get one at any autoparts store
Old Aug 12, 2014 | 02:00 PM
TX-SleeperC5's Avatar
Car: 1987 Trans Am GTA
Engine: 5.0 TPI
get a relay harness
I'm looking to go this same route with a dual fan set on a 87 TPI GTA... Will this diagram work as well for the dual fans ?
Old Aug 12, 2014 | 02:28 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
210F on and 200F off
Old Aug 12, 2014 | 02:31 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
"get a relay harness
87 to fan positive wire"
What happens when you shut the engine off after fan has already come on?
Old Aug 12, 2014 | 02:33 PM
midias's Avatar
Wire the + side of the relay coil to 12V Ignition like in my diagram.
Old Aug 12, 2014 | 02:35 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
That type of relay is not going to last long on any quality dual fan setup being rated @ 30A (from the looks of it...not to mention I can tell by the wiring it is Taiwanese and not rated J1128 for under hood temps) -the inrush current along on a dual fan setup is enough to kill it. But, this depends on what type of dual fans you plan to use. So will this type of single relay work? Yes. For how long? That's is up for debate.
Old Aug 12, 2014 | 04:07 PM
Joe Tag's Avatar
Even the stock dual fan setups have two relays, I would certainly advise doing the same. Both can be signaled by the CTS
Old Aug 12, 2014 | 04:08 PM
Joe Tag's Avatar
Old Aug 12, 2014 | 04:10 PM
midias's Avatar
One fan switch, 2 relays and a connector like this one with 2 wires to activate the coil on the relay.
http://www.mamotorworks.com/Corvette...e-kit-611171-1
Old Aug 12, 2014 | 04:20 PM
Joe Tag's Avatar
https://www.thirdgen.org/forums/cool...ml#post5807839
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 21, 2015 01:54 AM
