Leak in HVAC unit control
Old Sep 17, 2014 | 06:57 PM
rroyce85's Avatar
Car: 91 Camaro RS
I recently got a 91 camaro, the fan does not blow any air through the vents at all. There is a "hissing" behind the HVAC unit control, yet I still haven't figured out which line(s) is/are leaking or where. Could this prevent the fan from spinning at all, or would it have to be either the fan resistor or fan itself to cause the fan from not spinning?
Old Sep 17, 2014 | 07:41 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Leak in HVAC unit control
You need a new Air Conditioning Control Panel Vacuum Control Valve,
1983-1992 with a/c
It is on the rear of the hvac controls.
Possibly one of the vac. hoses connected to it may be broken or leaking also.
There are a few self fix posts on this site if you do a search.
https://www.thirdgen.org/forums/elec...ml#post5278772
This will NOT prevent the fan from working either.
You may have a bad fuse/connection or bad fan motor.
Many Cam/bird sites have them and they look like this
(factory piece is usually white):
Old Sep 17, 2014 | 08:08 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
https://www.thirdgen.org/forums/inte...anent-fix.html
Old Sep 17, 2014 | 11:57 PM
rroyce85's Avatar
Car: 91 Camaro RS
thanks guys :-)
Ghettobird52
Jul 5, 2024 11:18 PM
Casey Meyers
Mar 2, 2016 10:46 AM
777Shock777
Oct 29, 2015 04:30 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
