what is this hose for and what is the diameter?
Car: 1990 RS Camaro
Engine: 305 TBI
Transmission: T-5 stick
My brother has an 85 caprice 305 with the exact same radiator as my 90 rs manual.
He has a cap on an outlet on his radiator to bypass something, which i believe may be to the heater core but not completely sure. His rubber cap is leaking and he is trying to find a replacement cap but dont know the correct diameter. I am not around his car at the moment so i took a pic of my radiator for reference.
Any help on finding the diameter is appreciated.
Pics in next post
Pics in next post
Car: 1990 RS Camaro
Engine: 305 TBI
Re: what is this hose for and what is the diameter?
It is the hose directly below the clear reservoir hose. His rubber cap is cracked and leaking. Anyone know what this goes to and what the diameter is to solve this problem?
Sorry for the low quality pics and description i snapped and posted this on my way to work
¾"
Some cars have the heater connection on the rad, some on the water pump. Typical replacement radiators fit ALOT of car models; as many as possible. Therefore they put every possible feature for every one of those cars on every radiator. That's why you find a hose nipple like that one, a coolant level sensor, a trans fluid cooler even when you have a stick shift, etc.
Car: 1990 RS Camaro
Engine: 305 TBI
Thank you for your reply... makes sense to make a radiator as universal as possible.
I will find a 3/4 plug. Im sure they'll have what i need at autozone. Thanks again
You don't need a "plug"; the name of the right thing is "cap".
It's hanging on a card. It's a "Help!" item. Usually in the Cooling section, but might be in the Help! section with the throttle return springs, clutch bushings, door hinges, etc. In fact, might not be a bad idea to walk through that section, independent of the issue at hand; read every card; look at the parts, see what they do; might come in REAL HANDY someday.
Car: 1990 RS Camaro
Engine: 305 TBI
I found exactly what you are talking about but it seems a bit smaller than it should be. Ill post results shortly
Car: 1990 RS Camaro
Engine: 305 TBI
Definitely fit. Thank you for the info. The one that was on there was probably double walled which made it look much thicker than it was. Thanks again
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Pac J
May 17, 2020 10:44 AM
