Whats the best intake manifold for street use?
Old Nov 17, 2014 | 10:59 PM
Pickle83's Avatar
Looking for what kind of intake manifold i should use on my v8 short block 305. I dont really understand the engines for camaros yet. Ive been looking for intakes but most of the intakes say they only go up to 1986 and my engine is 1988? or supposedly it is. Help a boy out!
Old Nov 18, 2014 | 02:04 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: Whats the best intake manifold for street use?
What induction system will you be using?
4bbl carb, TBI (throttle body), or TPI (tuned port)?
If 4bbl carb then the edelbrock performer would be a good one.
If your engine and heads are 1988 you need an intake that fits the '87 and up due to change in the angle of the 4 center intake bolt holes.
This one if your running a carb http://www.summitracing.com/parts/edl-2104/applications
Old Nov 18, 2014 | 05:04 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
The biggest issue will be, are you using centerbolt head or not (86 and newer roller block motor) as mentioned above. What year is your engine block? Will it have a roller or flat-tappet cam?
I would say the Edelbrock Performer is the best for a Qjet/Carbureted car, mainly because it fits without issue (and it's a pretty good intake).
Old Nov 23, 2014 | 01:00 AM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
Rpm Air Gap
Old Nov 23, 2014 | 02:24 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Originally Posted by 92rsvortec350
Rpm Air Gap
The guys on power block on spike TV ran a performer rpm vs. Air gap rpm on the same motor. The difference on a dyno is maybe 2hp.
Old Dec 17, 2014 | 07:32 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
For a 305 itsnnot going to see high rpms I assum . I'd run a regular performer intake for what ever heads/carb you have.
Old Dec 23, 2014 | 10:52 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Understand that this question is wide open to interpretation. So many magazines and authors and website members have done comparisons that contradict each other. So many variables involved, vehicle weight, intended useage, rear gears, cam, compression, heads, EFI/carb/TBI.
Old Dec 31, 2014 | 04:55 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Stock hood - Edelbrock performer
Cowl hood - anything ya want
Old Dec 31, 2014 | 05:40 PM
firechicken1992's Avatar
Car: 92 Firebird--02 Grand Prix GTP 2Dr
Engine: Poncho 400--3.8 Supercharged
Transmission: T56 6 Speed--4T65EHD
Axle/Gears: Open 10 bolt 3.42--Internal 2.93
The kind that doesn't leak
Old Jan 3, 2015 | 06:07 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
ok.i'll ask.why is this in the cooling section?
Old Jan 3, 2015 | 07:20 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Bubbajones_ya
Aug 31, 2015 12:02 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
