squirrel cage problem, and vac. line
Old Jan 11, 2015 | 04:42 PM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
Hey guys, so my blower motor doesnt always spin, sometimes i have to hit it and it sounds like its hitting something. I did a search and found that the non a/c squirrel cage is shorter, i have an a/c delete box so is that most likely the issue? I pulled the motor off once and it spun fine and when installed worked maybe a week then started growling again. Now it wont spin at all. Also i just replaced a leaking heater core and the vacuum line going to the heater diverter valve broke back by the heater lines on the firewall, i was gonna splice it back but i dont know where it came from. So does vacuum open the valve or is it stuck shut till i fix it? Thanks.
Old Jan 14, 2015 | 08:45 PM
bigreed91's Avatar
Car: 1990 camaro rs
Re: squirrel cage problem, and vac. line
In case no one knows what a squirrel cage is its the fan on the blower motor, basically is the shorter fan needed for the a/c delete box from hawks thirdgen. And can someone please tell me where the vacuum line for the heater diverter valve goes around the back of the passenger side head, thats where it broke. Thanks.
Old Jan 15, 2015 | 12:46 AM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Can't say anything about the blower motor, but for the location of the heater valve it goes to a plastic hard-line which goes into a loom near the A/C box would be. There's a few pics of where it hooked up in this thread: https://www.thirdgen.org/forums/cool...ve-vacuum.html
Old Jan 15, 2015 | 06:27 AM
bigreed91's Avatar
Car: 1990 camaro rs
Thank you that helped, i guess im gonna be busting a loom open.
Old Jan 15, 2015 | 12:49 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If the AC version is longer, could you make a spacer under the motor mounts to give it more room?
Old Jan 15, 2015 | 01:05 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Go get a new motor for 30 buck and just get a Non AC Version
ACDELCO Part # 1580666 W/O AC
Vintageracer
Jan 10, 2020 05:33 PM
overdriv
Aug 20, 2015 03:52 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
z28addict8490
Aug 7, 2015 08:48 PM
