Need Bolts for Water Pump
Old Jan 18, 2015 | 10:58 PM
Trays87Bird's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
I've got a 87' Bird with a 2.8l V6; The bolts are busted off, and one I had to grind out of the block. Anyone know the size/length and threading on the bolts so I can get them replaced? Tried junk yards, and these cars are scarce here, so unfortunately and most people parting aren't willing to part with hardware bits (which is reasonable haha). I seem to be missing a lot of bolts and don't have a diagram for any of 'em, so I'm starting with this first.
Any help would be great. Thanks!!
Old Mar 2, 2015 | 05:16 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Need Bolts for Water Pump
Do you have a Fastenal near you? They should be able to match up what you need.
If you find ANY GM car with a 2.8L v6 from the 82-92 in the wrecker yards, you should be able to find the bolts you want.
Old Mar 4, 2015 | 09:50 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I couldn't figure out what ones you needed, you pick out the ones for the holes you need
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
MoJoe
Sep 24, 2015 09:12 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
