87 LT AIR DAM
Car: 1987 Camaro LT
Engine: 305 5.0 LG4
Axle/Gears: ?
87 LT AIR DAM
I have an 87 LT that im in the process or working on. I searched the forum but couldn't find anything on a correct air dam for the LT. Im sure its the same as the air damn on an 86 Berlinetta right? and if so, is that the same air dam as any other 86 camaro? can I just put any air dam in there?
Re: 87 LT AIR DAM
Same as any 82-92 Camaro
Firebirds are different (but would probably still work, since the car itself is the same)
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 87 LT AIR DAM
Just make sure you do the research to get the correct one. I bought a "new" one for my 84 T/A from classic industries and it was physically smaller than the one that was on the car and not all the bolt holes matched up. I'm not saying you'll run into the same issues with the Camaro piece, but I wanted to let you know what issue I ran into with mine.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 87 LT AIR DAM
82-84 Camaro Coupe Air Dams are only compatible with 82-84 Coupe and Berlinetta. ( 2-pieces )
85-87 Camaro Coupe Air Dams are only compatible with 85-87 Coupe, Berlinetta & LT. (3-piece )
All 88+ Camaro cars used the same Z28/IROC style front Air Dams.
None of these styles are directly interchangeable with each other.
Car: 1987 Camaro LT
Engine: 305 5.0 LG4
Axle/Gears: ?
Re: 87 LT AIR DAM
Thanks for the info guys!
I replaced my 87 bumper with that of an 86 berlinetta. so I'm still looking for that 3 piece dam right? The 3 piece consists of two smaller side dams and one long middle dam right?
Car: 1987 Camaro LT
Engine: 305 5.0 LG4
Axle/Gears: ?
Re: 87 LT AIR DAM
Ive heard of this happening a few times actually. Just wanna make sure i bolt the right one on there. Ill post a picture of what my current air dam looks like maybe you guys can tell me what that came out of
Car: 1984 Trans Am
Re: 87 LT AIR DAM
Why Can't you re-use the air dams that were on the original 87 nose ??
Here's a post showing a pic of the 3 pieces.......
https://www.thirdgen.org/forums/exte...nt-bumper.html
I know I still have a pair of the 2 larger parts,... don't think I've got the 3rd piece however. I'f your still looking for them send me a PM with your ZIP and I'll reply with more info.
