stripped
Old Mar 19, 2015 | 01:38 AM
sgp0511's Avatar
Car: 1988 Firebird
stripped
so was installing my radiator and i cross threaded the bottom transmission cooler line into the radiator.unscrewed and tried to connect line after i saw my mistake and now the line wont even try to start to go into female part of radiator. what are my options? i really dont want to get a new radiator because of this
Old Mar 19, 2015 | 03:40 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: stripped
With a standard SAE inverted flare fitting I would say to straighten out the threads on the male end with a SAE die. Then make note of the dies size and that will tell you the size of tap for the female and see if you can get it to bite. Your dealing with flare fittings and should only be tightened or loosened with a flare nut wrench.
OK, change of plans. I now see there is another option and is called the Bubble or GM Metric Flares. I will need to get a closer look at what I have in the garage. Unless someone can step in and make a correction or verification.
Old Mar 19, 2015 | 11:25 AM
Twin_Turbo's Avatar
Re: stripped
That's an inverted flare. The bubble flare has the sealing face the other way around. The end looks like =[ ]<> instead of =[ ]<<
= tube
[ ] nut
<> and << flared ends
Old Mar 19, 2015 | 04:35 PM
Engine: TBI,5.0
Re: stripped
I just got off the phone with a reputable Radiator shop and was told if its striped you done.
Its soft brass or aluminum and cant be taped or died. Unless someone steps in again and says otherwise.
You can get a new radiator that comes with adaptors if needed for $89.99.
This is what I have and is working perfectly. It also came with adapters to use with the transmission lines if nassary and that could be the problem your having in the first place.
http://www.oreillyauto.com/site/c/de...2465&ppt=C0331
Sorry
Old Mar 20, 2015 | 02:18 AM
Twin_Turbo's Avatar
Re: stripped
even cheaper, bypass the rad altogether and install a small external cooler. Done.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
Amillionoh7
Sep 5, 2015 11:44 PM
