AC and Smog pump help needed
Old Jun 7, 2015 | 04:11 PM
abovekingblood's Avatar
Car: 1989 Camaro RS
Engine: 350 TBI
Hello guys, this is my first post so I will keep it simple.
If I delete the smog pump, can I still fix my air conditioning? I don't know how the smog pump affects the compressor but I can't seem to find a thread with what I'm looking for.
Old Jun 7, 2015 | 11:43 PM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
Re: AC and Smog pump help needed
i just removed my smog pump and got a bigger belt n re-ran it
smog pump doesn't affect the compressor
Old Jun 7, 2015 | 11:44 PM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
https://www.thirdgen.org/serpentine/
i didnt buy the pully after i removed the smog pump but this image shows how to re-run ur belt
Old Jun 8, 2015 | 02:36 AM
Car: 1989 Camaro RS
Engine: 350 TBI
So I can just remove the smog pump and at those ugly hoses that it's connected to and still have the ability to run my air conditioner?
Old Jun 8, 2015 | 11:03 AM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
yes
Old Jun 11, 2015 | 04:00 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Without the smog pump delete pulley you may get some belt vibration. I've only read about it on here once or twice so I don't really know how big of a deal it is but it's something you should probably be aware of.
Old Jun 11, 2015 | 05:58 PM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
i have none of that..its tight as it was with the smog pump on as it is off
this belt from autozone Belt size "968K6" worked perfect.
before i removed the smog pump i checked the current belt
removed the smog pump n nice n tight
just make sure you follow the new path of how the belt goes on
not whats on your hood for stock belt path.
u can add it and use the old belt path, no harm in using it just another pully to replace when the bearing goes bad
eventually.
Old Jun 19, 2015 | 01:52 PM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
I did the same thing. But now I have the A/C working it throws the belt. Is there any way to avoid this without putting a smog pump delete pulley on?
Old Jun 19, 2015 | 05:48 PM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
if you followed that picture (minus the extra pully) and used this belt size
968K6 from autozone. then u shouldnt be throwing a belt
Old Jun 19, 2015 | 05:53 PM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
belt path..(ignore the delete pully obviously)
Old Jun 19, 2015 | 05:56 PM
gregl316's Avatar
I don't have an Auto Zone. The parts store I do have comes up with 3 different lengths when I asked them to cross reference it.
How long is it?
Old Jun 19, 2015 | 06:48 PM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
Part Number: 968K6
Weight: 0.6 lbs
Warranty: 1 YR
Belt Construction: K-Section
Belt Material: EPDM
Effective Length (in): 96.85-----------this is what your after
Effective Length (mm): 2459.99
Outside Circumference (in): 97.41
Outside Circumference (mm): 2474.22
Rib Count: 6
SAE Standards: SAE J1459,SAE J2432
Temperature Range Maximum (°F): 265
Temperature Range Minimum (°F): -45
Top Width (in): 0.82
Top Width (mm): 20.828
Type: Serpentine Belt
italiano67
Dec 11, 2016 09:21 AM
IROCZ1989
Jan 24, 2016 03:55 PM
beachrodder
Aug 25, 2015 08:05 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
