Help! 1990 Camaro RS 305 TBI Running hot
Old Jul 16, 2015 | 09:21 AM
ritalambert73's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
I am at my wits end, I have changed everything you can think of and my baby still runs hot when I turn on the AC unless I'm running 55 or more down the highway. What am I missing?
Old Jul 16, 2015 | 11:13 PM
jreyes106's Avatar
Re: Help! 1990 Camaro RS 305 TBI Running hot
I know your pain, I just went thru it and my pocket still hurts. Maybe I can shine some light into your solution. You mentioned that you have changed everything; what do you mean by that?
Old Jul 17, 2015 | 06:37 AM
Car: 1990 Camaro RS
Engine: 305 TBI
I mean everything from new radiator, fan, water pump, tstat, all new hoses, the only thing I haven't changed is the heater core but that is working fine. I'm not loosing coolant any where, but you can not run the AC in town without it running hot. I so don't want to give up on her, my first car was a 79 Z28 I loved her, now that all kids are grown and gone and I don't have to worry about hauling the neighbor hood around, ( I did love my Durango ) I fell in love with the 90's model and promised myself when kids were gone that's what I would be in. I did have the cat checked and it's fine, but she is running rich, she does have new plugs and wires, new oil, fuel filter, fuel pump, and I'm putting a new O2 in her today.
Old Jul 17, 2015 | 06:49 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
single or dual fan?
Old Jul 17, 2015 | 06:59 AM
Car: 1990 Camaro RS
Engine: 305 TBI
Single
Old Jul 17, 2015 | 07:03 AM
Car: 1990 Camaro RS
Engine: 305 TBI
Love your Iroc
Old Jul 17, 2015 | 04:41 PM
Car: 1990 Camaro RS
Engine: 305 TBI
Okay, so she will sit and idle even after running all day and never get hot till you turn on the AC. I'm good with that, however it's really starting to get hot here in Texas.
Old Jul 17, 2015 | 04:52 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
what is "HOT" like it boils over and will over heat hot or 230 hot?
-Dan
Old Jul 18, 2015 | 02:56 PM
tom86iroc's Avatar
Car: 1986 iroc
thanks lol another question start car and turn ac on does the fan come on ?
Old Jul 20, 2015 | 08:32 AM
Car: 1990 Camaro RS
Engine: 305 TBI
Just a little over 230
Old Jul 20, 2015 | 08:33 AM
Car: 1990 Camaro RS
Engine: 305 TBI
I have my fan set up to run when I start her up, so the fan is running all the time
Old Jul 20, 2015 | 08:35 AM
Car: 1990 Camaro RS
Engine: 305 TBI
An update, the O2 sen has helped a lot with her running rich, I don't smell the exhaust like I did before.
Old Jul 21, 2015 | 08:16 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Get an infrared thermometer and check the temp at the thermostat. If you're not losing coolant and it's not boiling over it may be that your gauge is off.
Old Jul 24, 2015 | 07:05 AM
Car: 1990 Camaro RS
Engine: 305 TBI
Okay, will do that come payday and give an update, however payday is next week
Old Jul 24, 2015 | 11:20 AM
Queball's Avatar
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
when you replaced rad n stuff, did you burp the system?
are you running straight AF or 50/50 ?
yes do check with IR temp scan, your gauges dont always tell the truth.
on my 92 RS, i use 160 stat during summer time, and run AC im lucky if it htis 220
then during winter time i use 195* stat..
Old Jul 26, 2015 | 07:52 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
As others have suggested, find an alternate method of getting the temperature other than the gauge. The gauge in my '87 pickup says I am running at 230, when reality is 200 on a hot day.
Also, do you have the lower air dam in place. I know that doesn't help when sitting at a stoplight, but it is an important piece of the cooling system that is often missing on our cars.
Old Jul 26, 2015 | 08:43 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
This is the factory operating temp of the car. You're fine.
You can install a 180 degree thermostat. Lower fan temp switch (225 degree is when the fans turn on from the factory. Get a 195 degree on switch with the 180 degree thermostat.
Beyond that, about the only upgrade is to a TPI dual fan or...jump right to an LS dual fan upgrade which is just about the best upgrade you can do for the cooling system for the car.
Old Jul 28, 2015 | 05:29 AM
Car: 1990 Camaro RS
Engine: 305 TBI
Yes I burped the system. And thank you for the tips.
Old Jul 28, 2015 | 05:31 AM
Car: 1990 Camaro RS
Engine: 305 TBI
Thank you, I have decided to go with the dual fan and new stat. You guys are great.
Old Jul 28, 2015 | 05:35 AM
Car: 1990 Camaro RS
Engine: 305 TBI
I will have to check that out, not sure. I'm just now really starting to get into her, I bought her for 900. and she needs a lot of love.
Old Jul 28, 2015 | 05:37 AM
Car: 1990 Camaro RS
Engine: 305 TBI
Running 50/50, Thanks for the tips
Old Jul 28, 2015 | 05:38 AM
Car: 1990 Camaro RS
Engine: 305 TBI
Old Jul 28, 2015 | 06:50 AM
Car: 1990 Camaro RS
Engine: 305 TBI
I need to replace the air dam, it's gone.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Jae992
Aug 27, 2015 09:07 AM
