1986 trans am 383 overheating
Old Sep 18, 2015 | 10:25 AM
randy210's Avatar
I put a new 383 stroked into my trans am. I have a new summit rad, 2-10inch 2400 cfm fans. I cant get the car to cool down, it is heating up to 260.
I have done
checked for air pockets
new high flow water pump
new summit rad, alum heater shroud
2 new 10in 2400 cfm fans
new 180 degree thermostat
checked plugs to see how car was burning
anyone have any idea's?
Old Oct 12, 2015 | 02:37 PM
thirteen20z28's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Re: 1986 trans am 383 overheating
Have you checked ignition timing? It will run hot if the timing is retarded. When does it get hot, at idle or going down the road?
Old Oct 15, 2015 | 02:58 PM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
thermostat might not be opening up all the way (even if it is a new one). could try drilling a 1/4 inch hole in the thermostat and see if that helps any.
Old Oct 15, 2015 | 03:43 PM
hectre13's Avatar
Car: 1984 15th Anv. T/A
Engine: HO 5.0
Transmission: TH700r4
Axle/Gears: not sure yet!
have you checked the temp with some external method (thermometer, etc) your gauge could just not be reading properly.
Reddeath210
Oct 6, 2015 08:20 AM
Pilotrick50
Sep 2, 2015 12:48 PM
mustangman65_79
Sep 1, 2015 03:51 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
