Water pump studs
Old Jan 16, 2016 | 01:05 PM
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Transmission: THM 700R4
Water pump studs
ok so i am replacing my water pump on my 1988 2.8 mpfi firebird. Also the Bolts or studs that are torx are going to be replaced with Hex studs for the pump. Would anyone know if these would work as replacements? If not where i could get replacement studs.
http://www.oreillyauto.com/site/c/de...6398&ppt=C0331
Old Jan 16, 2016 | 05:35 PM
Westech's Avatar
Car: 1991 Camaro RS
Axle/Gears: 7.6" 3.73 yukon locker
Re: Water pump studs
3.8 and 2.8 are 100% completely different.
Old Jan 16, 2016 | 10:38 PM
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Yes this i know. This is the only thing close to what mine are. I know they are not compatible and was not going to use them. just wanted to know if they would work or if anyone knew where i could get replacement hex bolts.
Old Jan 16, 2016 | 11:17 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Why not reuse the originals? If you must replace them any competent parts guy should be able to match them up for you.
Old Jan 17, 2016 | 01:21 AM
Night rider327's Avatar
Car: 1988 Camaro
Take a stock one to any hardware store, tractor supply, or home improvement store and go find the hardware/screws/bolts... Most will have a thread gauge sitting out to check your thread dia. and pitch. Find what yours is, then look for that size bolt and buy as needed.
Old Jan 17, 2016 | 10:33 AM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
I bought a water pump for my Camaro 305 .... came with new stud bolts (Napa) for the pulley attachment - is that what bolts you mean .... or bolts to the block ?
Old Jan 17, 2016 | 04:56 PM
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Right the actual water pump bolts. There are 11 in total 4 t50 torx 4 medium length ( not sure ) torx 30 and 4 small length torx 30 screws just like in that kit at orileys ( even though not compat) . I will check the hardware stores. Was just looking for a kit. I would reuse the originals but 4 were seized and i burned the heads of the bolts off and pulled the pump off. Just trying to find replacements.
Old Jan 18, 2016 | 08:36 PM
Car: 90 Iroc Vert
Engine: 5.0L
Old Jan 18, 2016 | 08:37 PM
Car: 90 Iroc Vert
Engine: 5.0L
Quick google for Chevy Water pump bolts... lots of kits available
Old Jan 22, 2016 | 03:20 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
the engine in question is a 2.8 V6, not a 305 or 350 V8... but i'm sure ARP makes some overpriced bolts that can be made to work with that, too..
i'd just hit a junkyard and find the bolts in an S10 or something..
Old Jan 28, 2016 | 07:06 PM
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Yeah i was thinking the same thing. The problem with mine is 4 of the bolts were stripped. So i melted the heads off pulled the water pump off and used a stud remover by lysle and removed 3, and broke remaining one. Now i have to pull off the harmonic balancer and the timing plate to finish removing the remaining bolt. What was supposed to be routine turned into a PITA !
Old Jan 28, 2016 | 11:35 PM
Car: 1988 Camaro
If you still need the bolts and ok with used ones. I have a 3.1 sitting out here now. I can pull the bolts for you. $1 each for the bolts + shipping
Old Jan 30, 2016 | 06:12 PM
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Will do! I have a friend with a junk 88 same year waiting to hear if he was able to get his out or not. If not i'll let you know for sure!
Old Jan 31, 2016 | 02:13 AM
Car: 1988 Camaro
Ok man, sounds good
Old Jan 31, 2016 | 05:43 PM
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Ok man, sounds good
Ok so he fell through. Looks like i'll be getting yours. Just let me know how much shipping is and i'll get you squared up. Should be 11 bolts.
1701-Z
May 31, 2016 09:32 PM
AmpleUnicorn88
Jan 23, 2016 04:04 PM
Sierra6
Jan 19, 2016 07:54 AM
'91CamaroRS
Jan 13, 2016 11:36 PM
Abubaca
Jan 13, 2016 09:46 AM
