Question about using an electric water pump on a street L98
Car: 1991 Camaro RS
Engine: TBI 305 soon to be a TPI 350
Axle/Gears: 3.23 Gears
Is it possible to use an electric water pump on a full street daily driven l98? I've heard people have mixed results with it i just want someone to clarify
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Question about using an electric water pump on a street L98
i would say it would overheat as it's a constant flow and doesn't change with rpm
Transmission: A4
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
I have a electric in my LT-1 Impala SS and it runs fine. Just my O2, I know its not an L98.
Mike
Mike
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
It will keep it cool just fine... But reliability comes into question
I have had a csr pump fail on me in less than a yr and that was not a daily driver. Wellll under the 2500 hr life they quote yet it died on me and luckily for me i caught it as i monitor my gauges frequently while driving
It rose from 195 normal temps to 230+ in a few seconds. Be careful if you go with one
Hard part is rerouting accessories for it to work. I had march performance electric water pump kit which is outrageous in price to begin with. Its just power steering and alternator and new crank pulley
Car: 89 Iroc-z
Transmission: TH400
Only way i would go electric is if you are full race looking for every ounce of power, or trying to set a bolt on L98 et record lol
Yes, every last ounce of power is tempting but my thinking on having one is the feature you would have on those boiling hot days and you're doing laps at the strip. At one time my fans were wired to a manual switch (as well as via the sensor) and it was handy to switch them on will the car was parked and pull some heat out of the rad. Having a the fans and pump would keep the engine reasonably cool I would think.
As for the bolt-on L98 record.....
Car: 89 Iroc-z
Transmission: TH400
And you shouldnt be racing much in the hottest days anyway unless you are a bracket guy on weekends that has to run each week
[QUOTE=skinny z;6034638]Your sig says a 94 Impala with a T56 and 4.56 gears. That must be a blast to drive
Can't even write that with a straight face.
It breaks loose in first and second but cruises at 70 like 2000 RPM.
Mike
What, it's a grandpa car, lol
Mike
[QUOTE=Realmac4;6035380] Ha! I'm a grandpa! Those Impalas have always been a favourite of mine. Should have bought an ex-police cruiser when I had the chance.
(Thanks to the OP for the thread loan).
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
For what it's worth:
No experience with an electric pump on an L98, but I've got an electric water pump cooing both my LT1's. My 84 isn't a daily driver,... but my 95Z pretty much is. ( gets used often - but not a whole lot of mileage ) Both electric Water Pumps have been installed for about 3-4 years and I've never had any issues with either car. I've got the Water Pumps relays' 'switched" power circuit connected to the fuel pump,..... so when the cars are running - the water pumps are pumping. I though about wiring in a manual toggle, but never needed to wire it that way.
