How do you feel about coolant that works with dexcool and old stuff
Old Jul 12, 2016 | 08:33 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
I needed to go buy some of the old green stuff for my 95 truck. But Oreillys told me that the orange stuff "works with dexcool and pre-1996". I was just curious if anyone trusts it.
Old Jul 12, 2016 | 08:56 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: How do you feel about coolant that works with dexcool and old stuff
Afaik, only Dexcool is orange. I could be wrong though. I've used green coolant that says its compatible with either, never had a problem. But then I haven't mixed it with Dexcool either, only used it by itself or mixed with the old green stuff.
Old Apr 4, 2017 | 02:17 AM
stahrman0612's Avatar
Car: 1986 Trans-Am
Engine: 305 4 bbl
Transmission: 700R4 auto
Axle/Gears: posi
It will probably be ok.......but the two mixed together will turn your coolant to a brown coffee looking muck!!!! Happened to me with my 07 Taurus.
Old Apr 4, 2017 | 09:19 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
IN these cars I only use green or prestone yellow any car coolant
Old Apr 4, 2017 | 11:18 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Me too but I ONLY use factory stuff from the dealer. They have special lubricants for the water pump and other moving parts that only the factory coolant has. Apparently coolant is a fairly complex thing.
Old Apr 5, 2017 | 03:10 PM
Abubaca's Avatar
If Oreilleys told me that my Iroc had four wheels, I'd go out and count just to be sure. I simply drive by that place and feel dumber.
Old Apr 5, 2017 | 03:14 PM
midias's Avatar
I hate dexacool coolant but that being said without a really good flush of the block and entire system stick with it and hope it does not completely eat your intake gaskets. For honda stay with honda blue and for toyota use the factory coolant or give it a good flush. Otherwise for the green prestone yellow is good stuff
Old Apr 5, 2017 | 06:23 PM
Engine: 350 TPI L98
Transmission: WC T5
Classic
Old Apr 6, 2017 | 12:38 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
They sell the conventional green coolant too. No need to take risks based on the advice of a possible high school drop out working the counter.
Old Apr 6, 2017 | 08:44 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
if you've ever seen the effects of dexcool firsthand, you'd never recommend it to anybody. don't buy it, don't mix it. this proves the kid at o'reily is an idiot by his advise.
Old Apr 6, 2017 | 08:56 AM
GASPEDDLER's Avatar
Napa makes a conventional green coolant under their house label/brand.
Old Apr 6, 2017 | 09:04 AM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Posts like this make me wish there was a "like" button on the forum.
Old Apr 6, 2017 | 07:43 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
You can find idiots "everywhere".
I went to my local Napa and asked a guy I have seen working there for years about brakes.
He looked me straight the eye and said , I don't know anything about brakes.
I took my car to a shop once because I was told he was a "Chevy" guy.
I even asked him to his face if he was familiar with my car. Yes was his reply.
Then he Crushed the under side at the pinch welds cracking the side skirting because he did not know where the lift spots were.
Like I said, there everywhere.
Old Apr 6, 2017 | 09:33 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Conventional green is still the right answer if there is brass in the cooling system. It works well, really well, with iron blocks too. But it is not a modern "extended life" coolant so you'll have to change it more often. I'll take that trade-off in a heartbeat.
Here is a good article if you are interested, although possibly dated by now. Different people will draw different conclusions. I chose the conventional green for my situation.
https://www.thirdgen.org/forums/ltx-...ml#post5970973
Old Apr 10, 2017 | 12:28 PM
Engine: 350 TPI L98
Transmission: WC T5
I read up on Dexcool. Bottom line: don't use it if it wasn't OEM.
Old Apr 10, 2017 | 12:37 PM
midias's Avatar
If it was OEM flush the system completely clear including the heater core and then fill with the yellow stuff.
Old Apr 11, 2017 | 06:14 PM
Car: 1986 Trans-Am
Engine: 305 4 bbl
Axle/Gears: posi
I thought he was asking about the universal Prestone stuff that is a flourecent yellow.....I was told you can mix with all types of coolant. I personally don't use it....I stick with good old green coolant. My son has Dex Cool in his 01 Bonneville and supposedly if you change it every 100,000 miles it works well??? I have heard horror stories of people who never change it past the 100,000 miles.
Old Apr 21, 2017 | 06:39 PM
JA411's Avatar
There's nothing wrong with dex-cool used properly. I have converted all of my older vehicles to it. Just keep a proper pressure cap and have no leaks. Same as green, oxygen is needed to have rust start. Proper cap, full level, no air (oxygen) no proplem. All these vehicles have pushing 175-200+K miles on them, again no issues.
Joe
Old Apr 22, 2017 | 06:41 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
I switched both of my 1996 Impala SS's over to conventional green coolant. I bought them both used and the Dexcool coolant was a mess.
My 95 Buick Roadmaster (same engine, same cooling system, except HD Towing Package) was OE w/ green and no problems.
Old Apr 23, 2017 | 04:11 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I tend to stick with whatever coolant that was put in at the factory, with one exception:
Anything that came with "conventional" green stuff, I've switched to silicate-free Peak Long Life (full strength). I also use this in my Acura as a replacement for Honda silicate-free (Honda only sells 50/50 premix; a gallon of distilled water is 89 cents at the grocery store ) .
The only vehicle I own that uses Dex-Cool is my '03 GMC M-van. I clear water flush and refill the cooling system (radiator, engine block and heater core) every 4-5 years. At 143k miles I've yet to have any cooling system issues. I use a GM licensed Dex-Cool (like Prestone) and not some Dex-Clone.
I have no idea what Toyota long life "red" coolant is, but it's in my Lexus cooling system. I just flush and refill with the Toyota stuff.
Dskeezy16
50
Jul 21, 2016 12:45 AM
mikeyt
Jun 6, 2016 08:12 AM
paw
May 25, 2016 06:32 AM
1992rs/ss
Interior Parts Wanted
May 12, 2016 12:32 PM
Knight224
Mid-Atlantic Region
Apr 30, 2016 12:57 PM
