Help me spend money on cooling renewal
Subscribe
Jul 4, 2017 | 05:03 PM
So When I leaned back the radiator to clean out the condenser I found a lot of the fins on the AC condenser were not in the best of shape. Meaning on a hot day here (99 plus) the car would run hot. Indicated over 230 and the AC would not cool.
So I think I need to have the condenser changed out. So if I'm going to have the radiator out I might as well change it also. It has been in the car at least 10 years, the time I've had the car. Most likely many more years than that.
So I am asking for opinions on what to buy. Known that there is lots of ideas and products.
I am listing what I think I would like to change out and welcome any help and brands and where to buy items. Hopefully this will help other members with questions .
AC condenser
Radiator( Original 1 row?) I am leaning to just using a original type.
Have a oil cooler in car.
Thermostat (have a newer 195 in car)
Radiator cap( newer stant in car)
Hoses are new
Pump has a little over 3000 miles on it.
Car 1990 GTA 305 with a 5 speed. AC and a oil cooler. Not modified.
Thanks in advance
Bob
Reply 0
Jul 4, 2017 | 05:35 PM
Re: Help me spend money on cooling renewal
All aluminium radiator
170 thermostat
New chip to lower fan set points to 180/190
Whatever A.C. parts you need to get that working. Condensor to insure good airflow to rad.
GD
Reply 0
Jul 4, 2017 | 05:50 PM
Thanks GD
Chevrolet Camaro Full Aluminum 3-Row Racing Radiator 3 Gen On Amazon by Auto Dynasty
Bob
Reply 0
Jul 4, 2017 | 07:23 PM
Doing some research on the radiator. Are radiators hard to find with fittings for engine oil coolers. Most seem to have fittings for trans coolers.
Reply 0
Jul 4, 2017 | 07:38 PM
You can use the trans cooler for engine oil if you want to... You won't find one with a specific engine oil cooler since they didn't do that from the factory I don't think. The oil cooler usually has coolant running through it, not sending oil to the radiator....
With modern synthetics, and a nice high capacity pan you don't need an oil cooler anyway.
GD
Reply 0
Jul 4, 2017 | 07:46 PM
What do you think about the Radiator on amazon. My wife likes that since we get 10 % back we try to go thru amazon as much as possible.
Reply 0
Jul 4, 2017 | 08:03 PM
I don't have experience with that one specifically but I bought a similar "cheap" Chinese unit from eBay and didn't end up using it at all because the fitment was so poor. I'm waiting to hear on the fitment of these:
https://www.holley.com/products/cool...rs/parts/FB189
I might end up buying one when they come out in July just to see for myself.
There are other options if you look around here on the forum, etc.
I can almost guarantee fitment will be terrible with that Amazon unit.
GD
Reply 0
Jul 4, 2017 | 09:29 PM
Champion has a heater hose fitting that should work with the factory oil cooler.Had one set up that way with my old motor.
Reply 0
Subscribe
