Aftermarket Fan Controller/Control Module Recommendations?
Old Jan 3, 2018 | 04:18 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
Hey all,
I am doing what essentially amounts to a rebuild of my engine bay. I have a 350 TPI that is getting a new Painless Harness PN 60102.
It seems I chose a harness that does not have provisions for the Dual Fans of the Iroc. So I am left with wiring up custom fan circuit. I already have a manual circuit which I am honestly tired of.
Ideally I would like an aftermarket adjustable fan control module that can screw into the block or tap into the signal wire of the stock engine temp sensor(the one for the ecm, not the gauge).
I called Summit and they showed me this one here but I am not sure if this will screw into the block where the stock sensor is.
If anyone has experience in this and could confirm this will work, or recommend something that is adjustable and automatic, that does not use radiator probes I'd be very grateful.
Thanks!
Old Jan 3, 2018 | 08:41 PM
Engine: 383 HSR EBL
Re: Aftermarket Fan Controller/Control Module Recommendations?
Never mind, I found a nice one on summit after a bit more searching.
If anyone stumbles onto this thread in the future I went with this one.
https://www.summitracing.com/parts/DAK-PAC-2750
Dakota Digital Programmable Dual Fan Controllers PAC-2750
Max_Maro92
Nov 20, 2007 04:27 PM
RallyRedTexan
Aug 24, 2003 05:23 PM
aziroc
Jul 19, 2002 02:44 PM
soulbounder
May 24, 2002 03:18 PM
