Thermostat Housing plug/connection
Old May 16, 2018 | 11:00 AM
juanmhiii's Avatar
Car: 85 Z28
Engine: V8 5.0L
Transmission: Automatic
I drive an 85 z28 camaro 5.0L carburated and was going to change the thermostat housing unit but noticed there was a connection connected to it and the new thermostat housing i got at autozone didnt have one. The connection seems to be leading into the car but no where near the engine. Was wondering what that line was/does and do i need to have it or can i just remove it? Thank you in advance.
Old May 16, 2018 | 11:38 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Thermostat Housing plug/connection
Take a picture and post it
Old May 16, 2018 | 12:03 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Is This The T Housing You Have,It Takes The Engine Coolant Temperature Sensor And A Ported Vacuum Switch.
Old May 16, 2018 | 12:25 PM
juanmhiii's Avatar
Car: 85 Z28
Engine: V8 5.0L
the housing unit looks something like that. To be honest not entirely sure but will post pictures as soon as i can and thanks
Old May 17, 2018 | 06:48 AM
Yours should look like GT's pics, and should have those same things in it.
The vacuum switch is the EFE TVS... controls the flap in the exhaust on the pass side at the junction of the manifold to the Y-pipe.
Old May 18, 2018 | 03:03 PM
juanmhiii's Avatar
Car: 85 Z28
Engine: V8 5.0L
yes thats exactly what they are so being new to the engine and all these things i take it these are essentials and needed for thr car to run properly?
Old May 18, 2018 | 03:22 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Yeah, sorta need them. You can get them both at car part stores, pretty cheap
Old May 18, 2018 | 03:55 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Depends you can add headers and you don't need it or you can wire it open, as for the other one unless you have the electronic carb you don't need it either.
Old May 18, 2018 | 03:56 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Depending on local emissions laws of course
Old May 18, 2018 | 04:21 PM
juanmhiii's Avatar
Car: 85 Z28
Engine: V8 5.0L
ok thanks for the help.
Old Jul 23, 2022 | 06:59 PM
Magparticle's Avatar
Car: 1984 Chevy Camaro
Engine: V8 305 5.0L
Transmission: Stock
Axle/Gears: Stock
hi I have a question about the electronic carb. I have a 1984 Camaro F 41 suspensions and I installed a buck four barrel carburetor with an electronic choke is my carburetor supposed to be attached to this vent port?
Old Jul 24, 2022 | 11:05 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Plug all those holes on the therm housing. Remove all the TVS units & reconnect the hoses directly to the carb.
That is what I did on my '84 Trans AM. Easy to do. I also removed the butterfly from the heat riser as it had started to seize.
The purpose of the TVS is to stop all vacuum to the engine until the block warms.
Old Jul 24, 2022 | 07:50 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Doesn't it also control the EGR as well?...
Old Jul 25, 2022 | 10:58 AM
72buickgs's Avatar
Car: 1984 Trans AM
I removed the egr valve (it had failed). Initially after I purchased the car, I place a small ball bearing in its vacuum so that the car would idle. But I made a cover from thin steel to replace the egr valve & purchased a gasket (actually several in a package) and mounted it onto the intake. Could probably send u a gasket if u want one.
Old Jul 25, 2022 | 10:37 PM
Engine: V8 305 5.0L
Transmission: Stock
Axle/Gears: Stock
okay cool, so I can essentially unplug it and remove the wires from the one that can support two vacuum hoses. and the thermostat sensor switch is unnecessary right? So I can plate it off or something
Old Jul 26, 2022 | 08:53 AM
72buickgs's Avatar
Car: 1984 Trans AM
U can. Do the removals one line at a time because the vacuum ports on the carb are specific to a certain to tvs. And remove the butterfly from the heat riser.
Old Jul 26, 2022 | 02:01 PM
Engine: V8 305 5.0L
Transmission: Stock
Axle/Gears: Stock
okay got it would there happen to be a forum on this, by chance. Also I’m thinking about getting rid of the ecu. I just need to figure out what are the benefits to doing so. And would I have to buy more stuff in replace of it. I need my lights and music lol. Or would I have to wire my own dedicated harnesses for the accessories in the vehicle.
Old Jul 26, 2022 | 02:05 PM
Engine: V8 305 5.0L
Transmission: Stock
Axle/Gears: Stock
thanks,I’m thinking I should probably take some photos lol so I can give a visual as well. I really appreciate y’all’s help. I was lost for a bit
Old Jul 26, 2022 | 02:23 PM
72buickgs's Avatar
Car: 1984 Trans AM
For the heat riser, I removed the butterfly + shaft completely & replaced with a bolt & nut.
If u have a carb or replace the FI with a carb, the why would u require an ECU?
Old Jul 26, 2022 | 06:35 PM
T.L.'s Avatar
ECM has nothing to do with lights or accessories. It controls the ignition timing, the air/fuel ratio, the torque converter lock-up (if auto trans), and emission controls...
Gumby
Jun 16, 2011 03:20 PM
Gumby
Jun 16, 2011 02:57 AM
cobrakiller1989
Carburetors
Mar 23, 2011 02:54 PM
Ovrclck350
May 4, 2001 09:03 AM
Night Hawk
Jul 26, 2000 02:29 PM
