92Z28 running a little too hot.
Old Jul 23, 2018 | 01:24 PM
pfsteichen's Avatar
Car: 92 Z28 convertible
Engine: 305 tpi
Transmission: Auto matic
I'm looking for some thoughts on my 92Z with 305 auto. It is running a little too hot. The fans are on a toggle switch and it is not using any coolant. On cool evenings it will go up to about 215-220 with both fans running. This is higher than it used to. Too hot to ever use the ac. Thoughts on where I should start? Thermostat? Water pump? I don't know where to begin.
Old Jul 23, 2018 | 02:25 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 92Z28 running a little too hot.
Sounds like normal operating temp. Stock the fan turns on at 226f .
Your gauge sender might be reading incorrectly.
Old Jul 24, 2018 | 11:05 AM
pfsteichen's Avatar
Engine: 305 tpi
It seems to me that on a cool night just cruising at 60 mph that the car should be cooler than 220 or so with both fans on. I'd like to get back to where I could re charge and use my ac. How would my car act if I had a thermostat stuck closed? I'm just fishing for thoughts here.
Old Jul 24, 2018 | 12:43 PM
dlinger's Avatar
Car: 1984 Z28 HO
Fans provide no cooling at 60 mph, air flow through the radiator does.
Is your front air dam in place and functional?
Under 45 and idling, does the fan operation lower the temp at all?
When is last time you flushed and replaced coolant?
Old Jul 24, 2018 | 01:46 PM
pfsteichen's Avatar
Engine: 305 tpi
Air dam is in place as it should be. I don't when on the coolant. The previous owner did change the the radiator, water pump, and thermostat, I could only guess that the coolant would have been changed then. All of that was about 35,000 miles ago.
Old Jul 24, 2018 | 01:49 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
https://www.eastwood.com/triflow
Old Jul 30, 2018 | 05:21 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Hot Cruise Night
You would REALLY overheat.
If your gage went that high you would see temps in the 300° bracket.
The engine would begin stalling and you would have to keep your right foot on the loud pedal to keep it running.
Use an IR thermometer to make sure your gage is accurate.
Does your radiator get hot or is it relatively cool?
Happy Racing !
When You See Fog Lights On In Good Weather Beware. WLow Performance Driver Ahead.
Old Jul 31, 2018 | 09:49 AM
pfsteichen's Avatar
Engine: 305 tpi
Re: Hot Cruise Night
Thanks I like the IR thermometer suggestion.
Austin19
Apr 25, 2014 02:00 AM
SomethingWild
Dec 14, 2011 08:23 PM
86TpiTransAm
Dec 10, 2006 06:51 PM
Xenodrgn
Car Audio
Aug 11, 2001 07:47 PM
