Lower radiator hose - 305 Firebird-does not fit!!!
Old Aug 10, 2018 | 07:10 PM
Ct1987's Avatar
Hi,
I decided to remove my 30 year old lower radiator hose and replace it with a new one. It was a little crazed.
I have tried 3 different brands and none of them fit. Dayco, Gates and Delco.
When I connect the hose to the water pump, and the other end to the radiator, the hose is too long and it folds under by the pump.
Does anyone other than me have this problem?
Thanks,
Louis
Old Aug 10, 2018 | 07:16 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Lower radiator hose - 305 Firebird-does not fit!!!
You have to trim them to the correct length.
Old Aug 10, 2018 | 07:25 PM
Ct1987's Avatar
Hi, the way the hoses are made, one end is larger for the water pump and the other end has a 90 degree bend to attach to the radiator. There is nothing to trim.
thanks for the reply.
Louis
Old Aug 11, 2018 | 07:51 AM
Sweatlock's Avatar
I also noticed this on my '92 Firebird 305 TBI - this was with a brand new AC Delco hose. I was concerned that the hose would collapse under suction, so I installed a stainless steel spring sold for an early Mustang application inside the hose. Now the hose isn't kinked and can't collapse, so no overheating concerns.
Old Aug 11, 2018 | 07:55 AM
Ct1987's Avatar
Hi Sweat, thanks for the reply. Where did you get the hose spring?
Louis
Old Aug 11, 2018 | 08:58 AM
TTOP350's Avatar
I know the WP side is larger. Can you post a picture of the issue?
Old Aug 11, 2018 | 09:21 AM
Ct1987's Avatar
Hi, unfortunately, I cant. I destroyed the hose trying to cut a 2 inch piece out of the middle.I connected the two halves with a metal connector. However have to go to plan next. I did not like the way it looked.
Louis
Old Aug 11, 2018 | 09:39 AM
gt4373's Avatar
Transmission: 5-Speed Manual
If You Still Have Your Old Hose When You Get Another New One Match It Up To The Old Hose And Cut Just Enough From Each End Of The Hose Until It Matches The Length Of The Old Hose.
Old Aug 11, 2018 | 01:37 PM
Sweatlock's Avatar
CJ Pony Parts, stainless steel spring for lower radiator hose, p/n HW769, $8.99 plus S/H.
https://www.cjponyparts.com/lower-radiator-hose-spring-stainless-steel-small-block-1965-1973/p/HW769/
I've used this spring on two cars, my '92 Firebird DD and my '69 AMX. At higher freeway speeds a lower radiator hose can collapse with the suction from the water pump. On older cars the spring was included with the hose - on newer cars, the composition of the material used is supposedly more rigid to prevent kinking or collapsing so as to eliminate the need for the spring. All I can say is, it's cheap enough and it worked for me.
Old Aug 11, 2018 | 02:56 PM
Ct1987's Avatar
I think my problem exists because I have a larger than normal water pump. I do not remember the brand at this time. I would have to look it up in my notes. The inlet is longer than a normal pump.
What I had to do was to cut off two inches in the middle of the hose and then connect both ends back together with an 1.5 inch brass coupler.
I did not want to cut off an inch from either end, there would not be enough to cover the pump and radiator fittings. My parts store did have a pony hose spring and i installed it in the larger side of the hose.
Thanks for the many hints
Louis
Black88Z
Nov 21, 2012 08:27 PM
Maverick H1L
Jul 30, 2012 09:48 PM
Damon
Jun 14, 2004 10:32 AM
bo ty guy
Sep 25, 2002 10:47 PM
