200 degree fan switch
Old Sep 11, 2018 | 05:30 PM
sjorgens's Avatar
Car: 1984 Firebird Trans am
Engine: 5.0 HO 4BBl
Transmission: one that kind of works
Axle/Gears: some that turn the wheels
I'm running a dorman taurus fan with a 195 temp switch. I have a 185 degree thermostat and it seems like the two things are basically fighting each other and the fan just wont turn off. Initially I thought I might be able to get a lower thermostat but I would have to go to a 175 and those aren't legal in CA? So the next thing would be to get a higher temp fan switch.
When my car last overheated, the engine shut off at about 221 degrees. That was the reading on the gauge on the aftermarket cluster I have installed. I have checked the temp at the top of the manifold with a handheld heat sensor and it read the same as what the cluster reads so I am taking it as being accurate.
What are my options in running a 200 degree fan switch? Is there some way I can set these things by dialing in a temp I want? Or do they always have to be a fixed value?
Old Sep 11, 2018 | 05:37 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 200 degree fan switch
Old Sep 11, 2018 | 05:44 PM
Engine: Lb9
Transmission: M20
And yes you can get a adjustable one
https://m.ebay.com/itm/Hayden-Fan-Sw...cAAOSwIphbUIOg
Old Sep 13, 2018 | 12:31 PM
sjorgens's Avatar
Engine: 5.0 HO 4BBl
Bought a 210 switch and a 200 switch from the ebay seller listed in that thread. Thanks for the link!
86budgetSC
Jan 9, 2003 10:12 PM
Trux
Apr 25, 2002 10:54 AM
Cam28_boy
Aftermarket Product Review
Nov 1, 2001 12:15 PM
TunedPort350
Sep 3, 2001 12:54 AM
southerniroc
Jan 14, 2001 11:31 PM
