witch one goes were ?
Old Sep 16, 2018 | 05:50 PM
Spenc's Avatar
Car: 84 z
Transmission: 700
Axle/Gears: auto overdrive
Gents, ready to hook up heater hoses following engine swap in 1984 Camaro. The two fittings have different size orifices though and I don't know witch one goes to intake and the other to the water pump. help and thanks
spenc
Old Sep 16, 2018 | 07:07 PM
NoEmissions84TA's Avatar
Re: witch one goes were ?
3/4" hose to the water pump
5/8' hose to the intake manifold
Old Sep 17, 2018 | 12:30 PM
Spenc's Avatar
Car: 84 z
Transmission: 700
thanks so much. didn't know if there should be higher or lower pressure going into the heater core. thanks
spenc
Old Sep 17, 2018 | 06:10 PM
They're designed such that the small one carries hot water to the heater, and the larger carries water that's been cooled in the heater, away from it.
Hottest point in the engine is the heads. Heated water flows from those, into the intake.
The port on the WP is on the suction side, the same chamber that cooled water from the radiator comes into.
Old Sep 17, 2018 | 07:25 PM
Spenc's Avatar
Car: 84 z
Transmission: 700
appreciate the explanation. and thanks again.
NEEDforSPEED
Jul 25, 2004 04:06 PM
FOX-GTA_89
Apr 19, 2004 06:05 PM
pred1tor83
Apr 9, 2002 12:37 PM
nativ
Jul 29, 2001 08:09 AM
Zar
Oct 27, 2000 01:57 AM
