Removing AC belt
Old Feb 17, 2019 | 11:49 AM
Sonny_T's Avatar
Car: Transam, 85
Engine: 305 HO, 4bbl Carb, G Engine
Transmission: 5 Speed
Removing AC belt
I have 4 belts. The AC belts run between crank, AC, Power steering & water pump, all 4. But Alternator belts runs between alternator, water pump & crank. The Power steering also has a separate belt between power steering and crank. It seems that water pump is run by two belts and power steering is also run by two belts. In both cases it is the AC belt that run as a second belt. Of course Alternator and Power steering belt can never be removed.
Question is, can I remove AC belt, or the AC belt is providing extra secondary pull to power steering and water pump?
Old Feb 17, 2019 | 04:20 PM
GeneralDisorder's Avatar
Re: Removing AC belt
You can remove it. Should be just fine.
propaintball96
Nov 23, 2015 02:07 PM
BladeX10
Aug 30, 2008 05:10 PM
Alexcoqui
Sep 3, 2004 10:26 PM
KW87GTA
Mar 27, 2001 10:36 PM
