3 core radiator upper support
Old Mar 14, 2019 | 09:08 PM
Camarothatcould's Avatar
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
I see them on all kinds of custom car build... but I cant find nay to buy. Suggestions?
Old Mar 15, 2019 | 02:16 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: 3 core radiator upper support
I made one for an aftermarket 4 core years ago. Was pretty easy with a small welder, metal saw, and a can of duplicolor truck bed liner. Used steel from Lowe's.
Took it off years ago to go a different route and built a new one for the original radiator that I reinstalled after discovering the 4 core didn't make a bit of difference.
here is a pic of the 4 core
Last edited by Aaron R.; Mar 16, 2019 at 11:38 AM. Reason: Removed second pic because it was different application.
Old Mar 15, 2019 | 07:17 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
fits my 4 core..
Old Mar 19, 2019 | 04:26 PM
GeneralDisorder's Avatar
Originally Posted by articwhiteZ
fits my 4 core..
Got a part number or manufacturer for that? I'm interested.....
GD
Old Mar 19, 2019 | 05:04 PM
GD
it is a nice looking part when finished.. another member made it..but did not quite finish it..he sorta moved on to a 2nd build of another style..and sold this unit off..I picked it up..and had it finished..
I have 2 aluminum Rads one is a 2 core. wIth 20AN fittings. and a 4 core..for reg hoses..if I cant use it..I will hit ya up..
ya never know how things work out...the 4 core will also be up for sale (new in box)as seen above in post..
note 4 core is set up with AN or reg hose for over flow.(at cap) and the silly temp bung is capped off with 1/8 npt..if ya don't need it.if ya need it ya just remove Plug..
so many unused parts...
Old Mar 20, 2019 | 03:18 PM
Best47's Avatar
I ordered a champion 3 core with the twin elec fan setup then just made a plate out of aluminum. I used body clips on the radiator after drilling 4 holes in the upper mount.
Old Mar 20, 2019 | 05:59 PM
clean looking set up..hows the shroud woking out..have been looking at them..
Waramp
May 5, 2011 11:28 PM
1995firebird
Sep 5, 2005 02:42 PM
