Question on original 87 Firebird heater hose
Old Apr 17, 2019 | 08:06 PM
Ct1987's Avatar
Hi, I need to replace my original heater hoses. There is one that comes from the pump and goes to the heater core and there is a smaller hose that tees off and goes the intake manifold. I cannot find the reason for the smaller hose. Do you think I can eliminate it? See photo.
Louis
Old Apr 17, 2019 | 08:31 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Question on original 87 Firebird heater hose
You can buuut it does kind of help reduce air pockets and cyl head hot spots
Old Apr 18, 2019 | 08:28 AM
Ct1987's Avatar
Thanks, I did not know, it makes sense.
I will keep it, I have been looking for an original but no luck.
Louis
Old Apr 18, 2019 | 02:11 PM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
when you replace hose see if the intake fitting can be removed its pot metal and will probably crumble! so be warned - my 87 ended up towed to dealer for warranty intake replacement Later I replaced with brass fitting, if you dont it could leave you high and dry at worst possible moment my .02c
Old Apr 18, 2019 | 06:52 PM
Ct1987's Avatar
I was looking at the manifold today, Its not going to come off. I am installing a new manifold, and will do brass.
Thanks for your input,
Louis
Tibo
May 9, 2012 06:22 PM
QwkTrip
Jan 9, 2012 06:41 PM
Blkdth87
Jan 18, 2007 11:24 PM
89rocs
Jan 17, 2004 02:38 AM
breathment
Mar 18, 2002 07:47 PM
