Replacing Gauge Temperature Sender
Old May 26, 2019 | 04:29 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
So my temperature gauge stopped working a little while ago. I did some tracing of wires and found that the green wire that attaches to the temp sender in between #1 and #3 was broken off and corroded. I'm planning on buying a new Temperature Sender but when I look at the autoparts stores online, Advance is the only store that seems to carry it (NAPA and Autozone) don't. They have two available a $60 one (https://shop.advanceautoparts.com/p/...erature+sender)
and a $20 one (https://shop.advanceautoparts.com/p/...erature+sender).
Which one is the correct one? My car is a 1986 Camaro IROC Z with TPI.
Also after I install the sensor itself, the actual connection on the green wire is corroded is there a part for that? I want to get my temperature gauge working for the summer, I will be driving a lot more and longer distances.
Old May 27, 2019 | 01:13 PM
Re: Replacing Gauge Temperature Sender
Either of those sending units should work. No idea why 1 is $20 and 1 is $60; they're usually in the $15 - 20 range.Doesn't particularly matter what your car is: the sending unit has been the same since they started using electrical gauges back in the 50s, up until the gauge became part of the ECM's function. Only difference is, sometime in the 70s they changed the size of the hole in the head, from 1/2" pipe to 3/8" pipe. If your heads are the stock ones for your car, they'll have the smaller size. Although it looks like maybe the $60 one is the larger size.
Part # at AZ is TU66.
Yes you can cut the old connector off of your wire and crimp a new terminal on it. It's a generic 1/4" spade.
Old May 28, 2019 | 10:21 AM
Engine: LB9 305 TPI
Awesome! I ordered it and I am going to pick it up later today.
notrabies
Jul 29, 2016 09:39 PM
leo037
Mar 25, 2009 02:29 PM
lighthorseozzy1
Nov 2, 2003 11:10 AM
