1986 Single Fan Not Turning On Again
Old Jul 9, 2019 | 06:16 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
I have a 1986 Camaro IROC Z TPI 305 with the factory single fan. My car does not have a fan switch. About 4 years ago, the first time this had happened my fan motor was bad so it was replaced a long with the relay. About 2 years later my fan stopped coming on a second time and this time it was the pig tail the fan plugs in to. Now it's not coming on again. The ECM was also replaced about 4 years ago due to a separate issue (car stalled as soon as I stepped on the gas).
When I turn on the AC the fan does not turn on. Also after doing city driving with my car at 230-240 or so, the fan was not on when I pulled into a Walgreens parking lot. (Temperature was verified by both the gauge and a Temp gun). Any idea what else it could be?
Old Jul 9, 2019 | 06:50 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: 1986 Single Fan Not Turning On Again
Have you checked the fan relay? Ive seen those wires burn up leading to it.
Old Jul 9, 2019 | 07:43 PM
Engine: LB9 305 TPI
I'll check the wires and the pig tail for corrosion tomorrow. That's a good place to start.
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
my car overheated because fans(i have 2) stopped working. they wont come on when the ac is on either. where is the fan relay at?
Old Jul 9, 2019 | 08:45 PM
Engine: LB9 305 TPI
On mine it's right next to the radiator on the passenger side. It's a square shaped cartridge. I'll take a picture tomorrow and post it here.
Old Jul 10, 2019 | 11:37 AM
Engine: LB9 305 TPI
Here is the picture of the relay.
It's usually either black or white. I believe mine is a Standard Auto Parts brand.
It's located right next to the battery
Old Jul 10, 2019 | 11:46 AM
Engine: LB9 305 TPI
I noticed I have a cut wire on my fan relay pigtail. Does anyone know what this could be to?
When I tested the pig tail for connectivity, I got -630 ohms. Anyone know what this means?
I did some more digging. Anyone know what this wires are to?
Or these two connectors?
Old Jul 10, 2019 | 11:49 AM
Engine: LB9 305 TPI
I took a look at my fuse box and couldn't find a fan fuse. I've replaced several of the fuses over the years but never the fan one. On all of the diagrams I see where my Fan fuse should be there is a 15 amp fuse for LID above the 25 AC fuse. Is anyone else's fusebox like mine?
boeingcorp
Apr 19, 2014 05:48 PM
KnightmareCS
Dec 22, 2010 12:25 PM
norcalz28
Dec 19, 2010 01:09 AM
wanab03ss
Jul 13, 2008 06:16 PM
