Dual fan issue
Old Jul 10, 2019 | 10:43 PM
Klleino12's Avatar
Car: 1989 gta ws6
Engine: 5.7
Axle/Gears: 3.47
Dual fan issue
Ok, changed the coolant fan switch. Neither funds come on. Well the driver’s side comes on for 20 seconds and then neither come on. I am clueless on what to do. Help! In terms that I can understand. 39year old woman. I was looking for the relays or what to try next. 1989 trans am 5.7. If you are going to be mean or rude, please don’t respond. I want to do this myself and not hire someone so please help! Yes I have read threads on here. Multiple times!!
Old Jul 10, 2019 | 11:00 PM
Klleino12's Avatar
Car: 1989 gta ws6
Engine: 5.7
Axle/Gears: 3.47
Re: Dual fan issue
The ac does not come on either. I tried turning it on and no fan came on
Old Jul 11, 2019 | 04:34 AM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
Re: Dual fan issue
If you want to be able to do it yourself can you read schematics? That would be the first place to start. austinsthirdgen has schematics that will help you. See if the relays are getting power form orange wire first. If they are you need to make the relays work. Look at the schematic for your car and the wire that triggers the relay will need to be grounded to body of car (gray wire from AC switch or dark green/white stripe wire from computer). I would trigger the wire from the AC. Just remove it from the AC pressure switch and touch it to the body. If that makes the fan come on you have an issue upstream or towards your computer. If it doesn't check you wiring all over. You may have a burnt wire. The main connector near the relays can have a burnt wire in the connector. It is the big six pin connector. Pull it apart and look for toasty wires.
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
Edit: You have to have the key on to test the grounding out of the gray wire. Not running, just in the on position.
Old Jul 11, 2019 | 07:55 AM
Klleino12's Avatar
Car: 1989 gta ws6
Engine: 5.7
Axle/Gears: 3.47
Re: Dual fan issue
I looked at some relays and have no idea which two are the fan relays. This winter I am going to change out the fans and radiator. I just wanted to be able to drive it until then and it gets pretty hot without the fans
Napster134
Jan 24, 2018 03:06 PM
dredre08
Jun 1, 2010 01:16 AM
tyrvidar
May 13, 2007 06:02 PM
aziroc
Jul 19, 2002 02:44 PM
