Lower Radiator Hose ? ...
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
I just got a new lower radiator hose. Are these hoses supposed to have a spring inside to prevent collapsing under suction?
This new hose doesn't have one...
Engine: LB9 305
Transmission: AT
Re: Lower Radiator Hose ? ...
Well, I started in the Auto Repair business as a Parts Manager, back in 1977. At that time lower hoses DID have a spring, to keep the hose from colasping at higher speeds, due to the water pump, drawing on the lower hose.
Over the years the springs have pretty much disappeared and I do not know why. I might try to email Gates and get an answer.
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
I decided to put one in. ordered it off of either jegs or summit for around $10. peace of mind basically.
Engine: LB9 305
Transmission: AT
Reply from GATES
"Number one, We stiffened up the sidewall material (Newer technology) and secondly, a proper running cooling system running 16 PSI technology would not collapse a hose under pressure"
CHRIS
1144 Fifteenth St, Suite 1400
Denver Co 80802.
CHRIS
Denver Co 80802.
The "collapsing lower hose" thing is one of those anachronisms like "vapor lock" that's left over from days long gone. It is ONLY possible in a cooling system that isn't properly pressurized; i.e. one that has a defective rad cap or the like, including those that have been "improved" by the same kind of people that think that cutting up wiring harnesses is an "improvement".
I haven't had a car with a lower hose with a spring in it since AT LEAST the late 70s. IIRC my 78 & 79 Z28s didn't have that anymore, and my 83 CERTAINLY doesn't. No other car I've had since then has either. It's simply not necessary in a properly maintained cooling system so the mfrs don't bother with it.
Thanks, guys!...
BlueZee28
Apr 8, 2011 11:40 AM
