Once Every Few Months My Single Fan Stops Working. I Can't Figure it Out
Old Aug 28, 2020 | 02:01 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
So I have a 1986 Camaro IROC Z with the single fan with no fan switch. Last year it stopped working. I replaced the fan motor, the pigtail, relay, the CTS, the temp sender, the ac compressor pig tail and the ECM. It never worked. I did buy a fan controller and got it working. Now it's not working again. It was working fine this morning but then it stopped working. I can't figure it out.
Old Aug 28, 2020 | 02:27 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Once Every Few Months My Single Fan Stops Working. I Can't Figure it Out
I would bet the relay is worn out...
Old Aug 28, 2020 | 03:42 PM
Engine: LB9 305 TPI
I replace it again. When I do though nothing happens.
Old Aug 30, 2020 | 12:22 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Check various ground wire contacts are clean.
Old Sep 2, 2020 | 04:57 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
FanTastic
Troubleshoot before replacing parts.
Apply battery power to the fan to see if it runs.
Use a voltmeter to see if there is power on the
orange or red wire at the relay.
Is there power there?
You can test much of the circuit by having the key in the RUN position then grounding pin B of the ALDL
(Assembly Line Diagnostic Link).
HappyRacing!
Viewing Scenery At 330 MPH Is Not Easy
Vinscully50
Jun 29, 2020 05:31 PM
Vinscully50
Jul 10, 2019 11:49 AM
sjcrazyjuggalo
Sep 16, 2008 10:46 PM
Larry Dunlap
Mar 27, 2002 09:59 PM
Kiss_My_SS
Mar 19, 2002 10:38 AM
