Radiator is stuck by 1 line
Old Oct 15, 2020 | 10:34 PM
gscroll's Avatar
Car: 91 Z28
Engine: L98 5.7L 350 TPI
Transmission: It works.
Hi everyone,
So I had the heater core removed and a new one installed, while also replacing the radiator. Two issues came up: The head to the transmission cooling line was stripped, though it finally did come off.
The second line is stripped as well, and it’s the only thing holding me back from removing the old radiator.
I would like some feedback. Should I just cut it and replace the entire line of both lines? Should I cut the ends off and maybe do some kind of AN fitting? The new radiator is a Champion 3 core radiator (got it on sale!) I’m open to suggestions.
Old Oct 16, 2020 | 09:11 AM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
Re: Radiator is stuck by 1 line
You can buy them new and pre-bent. I would just cut the old line and install new stainless lines. AN fittings are nice but require some fab work to make them fit with adapters and such.
https://www.thirdgenranch.com/catalo...476458449ef727
Old Oct 16, 2020 | 06:16 PM
NoEmissions84TA's Avatar
Quick and dirty - cut each line and use 2 of these with rubber transmission cooler hose and fuel-injection style hose clamps at both ends.
Better - replace both lines with new stainless steel. Where are you? I ordered an extra pair by mistake. https://www.summitracing.com/parts/c...yABEgIwC_D_BwE
Old Oct 16, 2020 | 06:22 PM
gscroll's Avatar
Car: 91 Z28
Im located in the SoCal area.
Old Oct 16, 2020 | 06:32 PM
I am in CT. Shipping across the country would kill this deal.
wishoradream
Mar 27, 2013 06:10 PM
Tonglebeak
Jun 2, 2010 03:50 PM
roughskinjrz
Sep 23, 2005 11:06 AM
speedingpenguin
Jan 18, 2005 08:09 AM
