is there a reason my transmission line wont go back in the lower part of the radiator
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
why the **** wont it screw back in?
i got the line going to the top of the radiator, but when i went to screw the bottom one in, it feels like it starting to tighten, it just pops back out
did i strip it, if i did, am i into a big job
this is ****in pissing me off
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The top line is usually a bit more flexible and accessible because of the vertical run, so try doing the bottom first and then the top.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
yeh i screw it in, it feels like its going in, then all of a sudden it gets loose and you can haul it out...im not sure what im doing wrong, ill take out the top one then try the bottom one first i guess
i wouldnt have even taken out the rad, but my new chrome hoses were a bitch to get it, so i took out the rad for easier access, im getting really pissed off.
i have a q, it screws in to a point where it stays and if i touch it it is snug, but if i tighten it anymore it comes loose again and pops out.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
not a good thing, i just want it to last until i save up for t56, maybe a month..
you think it will be fine til then, anyway i can fix it to temporarily stay
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
cuz i wont need the transmsision lines going to the rad anymore, i will just plug them off, but i need a way for it to work temporarily for now without changing the lines.
any suggestions?
any suggestions?
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
buy an external tranny cooler for now and bypass the radiator. go to the junk yard and look for one or buy one and sell it on ebay after you do the t56 swap
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
tranny cooler will bypass the radiator, can someone tell me how that works?
wizard i live in toronto, on m5g2m4 get me shipping quote
does it work?
does it work?
you take the lines off the tranny and run it to the cooler instead. you are supose to use both the radiator and cooler but since its temp. i wouldnt worry that much. maybe get a tranny temp gauge to moniter the temps
Car: '85 Z28
Engine: 355
Transmission: TH350
does it work?
does it work?
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
so it works fine, do you have the lines that will go from the transmission lines to the cooler?
and how does it mount on the transmission
Car: '85 Z28
Engine: 355
Transmission: TH350
Yeah it has a couple feet of hose attached to it. You would just slip the hose over your tranny lines and clamp 'em. It mounts in front of the radiator. There's some bracing up there that it's real easy to zip tie it to.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
oh so your running rubber hose, i thought that wasnt good. it mount in the front of the radiator, i thought this wasnt going to hook up to my radiator, cuz i stripped the bottom part where one of the lines go into, the top hole is alright as the line is in there.
you might have to explain this a little better, as im new to trannys
Car: '85 Z28
Engine: 355
Transmission: TH350
The cooler has 2 ports each w/ a piece of hose attached. You would slide the hose over the end of each tranny line. A tranny cooler is alot like a small radiator if you can picture that. Look around the website I'm sure you can find some examples, if not I could send you a pic of it.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok what im getting from this, is that the cooler has 2 holes just like the ones on the radiator for the lines coming from the transmission will go to, right? so i can block off my radiator with plugs where the transmission lines were, and take out the steel lines altogether, because i will be using the ones that come with yours right?
how do i mount it on the transmission?
Engine: 383 Carb
Transmission: 4L60
You'd cut the ends off your factory steel lines, slide the rubber hoses over the cut ends, and secure them with hose clamps.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok i get it now, any certain place i should cut them, or just near the transmission, and slide the rubber hose over my steel lines, and im finished.
how do you get the cooler to work? do you fill it with coolant or anything before you install? and does it just bolt to the transmision?
Engine: 383 Carb
Transmission: 4L60
You don't want it near the transmission, you want it mounted in front of the rad so air can flow through it.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
so id mount the cooler near the front? how big is it? does anyone have pics of one install in a car, im confused lol
Car: '85 Z28
Engine: 355
Transmission: TH350
You don't have to cut your tubes at all. Just slide the nut back and push the hose over the end. If you leave that flare on the end it will help the hose seal and hold the pressure.
No coolant!!!!!! Tranny fluid flows through it from your trans. When your trans is hooked to your radiator, it's really just using the cooling effects of the radiator to help cool the trans fluid. The coolant in your motor doesn't go through your trans at all.
You will mount it in the nose of the car in front of the radiator. There's enough hose w/ the cooler I have to do that easy. There's room just to the left of the radiator for the hose to pass through and hook to the tranny lines.
Also, you don't have to plug your radiator. Nothing will be going through there w/ the lines unhooked........
Are you starting to get it???
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
so where the lines went into the radiator now, i can leave those unhooked? what about the tranny liquid that was going through the bottom parts do i have to empty the rad?
yeah i got it, it will sit in front of the rad, how do i bolt it down or will it just sit there.
do you take paypal? so total 32$, it works right, lol, just to make sure.
Car: 1992 Camaro Z28
I've got this hookup on my car, as I did the same thing (I feel your pain on this, it sucks). I will snap some pics of the mount and the lines this weekend and post them so you can see how I did it
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok thanks alot, when i stripped it, i thought i was screwed and that it would be a big job to fix, but i guess not, just install a cooler, hopefully it works til i can get the t56.
1992 Trans Am
May 10, 2023 07:19 PM
