Cooplant temp sensor
Old Nov 11, 2020 | 07:57 AM
30coupe's Avatar
I have a streetrod that's has a complete 1989 camaro 5.7 drivetrain and wiring harness . My question is the coolant temp sensor on the passenger side below exhaust , is this for radiator fan control ? Does it control anything with the ecm ?
Old Nov 11, 2020 | 08:05 AM
Re: Cooplant temp sensor
Yes. No.
Old Nov 11, 2020 | 08:59 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If your referring to the sensor in the block down low on passenger side that’s the knock sensor. Secondary fan switch is in the head on passenger side between cylinder 6&8.
the ecm does control the primary fan by using the coolant temperature sensor in the front of the intake. The drivers side sensor is for a gauge.
jaweiss
Jul 29, 2011 10:27 AM
Bobby_80s
May 24, 2008 09:38 AM
kboehringer
Sep 6, 2005 09:41 PM
hunterdaj
Jun 12, 2005 12:03 AM
zedder 1 9 9 0
May 1, 2002 08:22 PM
