Pasenger side Temp sensor
Old Apr 30, 2002 | 11:35 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
Is the passenger side temp sensor strictly used to activate the passenger side electric fan or does it send vital ifo to the ECM to help with engine management? The reason I ask is because I have never seen my passenger side fan activate(even when engine temp is above 220), it is working though( I switched wires around and it came on). I am having a problem with a bad miss once the engine warms up( I have replaced so many things with no real results) and I'm wondering if the ecm is getting enough input about engine temp. The temp sensor in question is new, however the harness connector disintegrated when I pulled it off last year and I had to wire a new connector into the harness. I'm not sure that it is working now. I'm wondering if this could be contributing to my engine stumble?
Old May 1, 2002 | 08:22 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The passenger side sensor is only used for a fanswitch, when temps get way high (about 240*F).
There is no info from this sensor that affects anything but the 2ndry fan control.
Bert87
Aug 23, 2015 03:50 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
bamaboy0323
Aug 15, 2015 07:20 AM
timonator
Aug 11, 2015 09:56 PM
