Derale fans
Old Mar 16, 2021 | 08:21 AM
87TCamaro's Avatar
Car: 87 T top iroc z28 camaro
Engine: 355
Transmission: 700r
Axle/Gears: 27spline factory 9 bolt w 355 gears
Derale fans
Ok guys I'm gonna be upgrading my cooling system on my camaro with a three row radiator and derale fans...my only concern is what it will hit. Ect. Steering box, and or water pump anyone have any info on this tia
Old Mar 16, 2021 | 09:18 AM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Derale fans
I have a car here im working on with a 3 row rad and derale fans. the shroud is pretty thick. I have to trim away the area by the steering box for it to fit. ill get a photo in a bit.
Old Mar 16, 2021 | 11:31 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: Derale fans
I barely fit a 2 row mishimoto radiator with a dual derale fan setup in my car. I don’t have A/C which helped. The back of the fan shroud is like 1/4” away from the steering box.
Old Mar 16, 2021 | 09:47 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Re: Derale fans
Dewitts radiator, derale shroud. With stock accessories, you'll have plenty of room. I'm using an aftermarket serpentine setup, and it's tight. I set the shroud up so I can slide it right out the top in under a minute, without needing to go under the car, in order to access the belt. Obviously trim as needed around the steering box.
fteufert
Apr 20, 2015 12:37 AM
327sleeper88
Sep 13, 2011 09:05 PM
toogood002
Oct 5, 2006 03:12 PM
Blackroc86
Aug 8, 2005 05:36 PM
87Formula356
Aug 11, 2004 08:54 PM
