Griffin rad + Fans + stewart pump?
Old Jun 24, 2004 | 09:48 PM
87Formula356's Avatar
Car: 87 Formula Firebird
Engine: 5.8Ltr 356
Transmission: WC t-5...... probobly go boom soon.
from what i read on these boards, since i want to re-do my whole system i would want a Stewart water pump, a Griffin Radiator, and Aftermarket cooling fan (s).
the problem is know one has nailed down the specifics, i want a big radiator with fittings for my heating and draining, i want aftermarket fans, but i don't know how much to expect to pay for them, or if i can get them in a combo from griffin. At the griffin website they don't post prices. And, which stewart pump do i get? the short or the long? what do our cars use? the hand polished one looks nice.
Old Jun 25, 2004 | 08:13 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Here's what you want/need.
Summit racing, dual 1" core universal fit griffin race radiator. $179
http://store.summitracing.com/defaul...=gri-1-25272-x
You could run the bigger dual 1.25" core version but it would require custom upper and lower radiator brackets and it's $60 more. The dual 1" core version (above) can use your stock mounts with very little modification.
Spal dual 11" high performance fans. $235
http://www.carshopinc.com/product_in...51071/30100846
Stewart stage 1 water pump (long). $69
Part number depends on weather you are full serpentine or V-belts (check your year).
Old Jun 25, 2004 | 06:02 PM
Engine: 5.8Ltr 356
Thanks John, the info is really awsome. but i have a few more questions, What do i do about my heater and overflow hoses? are there fittings for them? and will i need any extra hardware to mounth the fans?
Old Jun 25, 2004 | 06:04 PM
Engine: 5.8Ltr 356
Shucks, no hand polished version for us huh?
Old Jun 25, 2004 | 07:49 PM
Engine: 4.0L
Your heater hose will have to go to the top of the water pump like older SBC's with the universal Griffin radiator. You will also need an external trans cooler.
You will need hardware to mount the Spal fans.
The Griffin has provisons for overflow hose.
Griffin does make a direct fit version with heater return and trans cooler but it is almost as much as Be Cool's direct fit radiator.
Engine: 4.0L
Yes you can get a long water pump hand polished from Stewart. I believe you have to get the stage 2 pump though.
Old Jun 25, 2004 | 07:56 PM
Engine: 5.8Ltr 356
is there a downside to the stage 2 pump?
Old Jun 25, 2004 | 08:10 PM
Engine: 4.0L
Yes, it is extra money.
Old Jun 25, 2004 | 08:16 PM
Engine: 5.8Ltr 356
lol makes sence... is there anything i can do about my heater fittings on the aluminum radiator?
Old Jun 25, 2004 | 08:19 PM
Engine: 4.0L
It's just one fitting. Nothing can be done. I have a TIG welding expert and he wouldn't weld in a fitting due to the epoxy (internal) on the tanks. You MIGHT be able to add a compression type fitting that sandwich's the tank so you could hook up your heater hose but why? There is a perfect port on the top of every SBC water pump.
Old Jun 26, 2004 | 02:09 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I used the Griffin 31"x19" with 1-1/4" tubes. I did have to cut sheetmetal on the bottom of the radiator support to get it to fit.
I also made a new top cover out of aluminum.
Like John said above, just get a hose fitting to replace the plug in the water pump and connect the heater hose there.
Performance Stainless has some really nice fittings, so that's what I used.
http://performancesst.com/customer/home.php?cat=7
Stewart pumps are great and I've had one for a couple years with no problems.
Spal fans are some of the best as well, so I'll second all the above recommendations.
-Rich-
Old Jun 26, 2004 | 06:26 PM
Engine: 5.8Ltr 356
thats a great idea, there is a closed port that is unused on the water pump? which fitting part # is the one that fits or that you reccomend. also i want to get those fan switches from hayden that operate individuly from the stock fan control, but the article says to get them at pep boys and there are none around here, so do any of you guys know off hand where to get them? and do the fans come with the required hardware to install them?
Old Jun 26, 2004 | 06:28 PM
Engine: 5.8Ltr 356
oh sorry about the repeat questions, i missed the one post where you answered my question about needing hardware and the pump fitting.
Old Jun 26, 2004 | 11:18 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
[QUOTE]Originally posted by RICH92RS350
[B]I used the Griffin 31"x19" with 1-1/4" tubes. I did have to cut sheetmetal on the bottom of the radiator support to get it to fit.
I had tocut my rad support on the drivers side top to fit it. Do you make aluminum covers? Someone here was going to but they lost the shop to work out of. I would pay to have one made....
Old Jun 27, 2004 | 08:07 AM
Engine: 5.8Ltr 356
i was asking which fitting would fit on the water pump, since the pump hasn't arrived yet it would be nice to get both at once
Old Jun 27, 2004 | 08:46 AM
Engine: 4.0L
Just use the one off your radiator. I don't remember the size on the pump, I'll be Stewart does if you order a pump through them they will probably give you a fitting.
Old Jun 27, 2004 | 08:50 AM
Engine: 4.0L
[QUOTE]Originally posted by CaptPicardsZ28
The stock plastic upper radiator support will NOT work with the dual 1.25" radiator. You can slightly modify it like CaptPicardsZ28 did if you have the dual 1" radiator.
You should not have to cut sheetmetal at all for either version.
Old Jun 27, 2004 | 12:33 PM
nexus6's Avatar
i knoiw its a liitle late but i had griffin make me one with a 5/8 heater hose connection.im trying to get it in today.but im having issues with the stock fans clearing the radiator.they want to rest on it and wont turn
Old Jun 27, 2004 | 01:23 PM
Engine: 4.0L
You need to add a spacer to set the stock fans back some away from the radiator. Might need longer bolts also.
Old Jun 27, 2004 | 03:36 PM
I used two washers on the top and bottom of the fan. Works fine.
Old Jun 27, 2004 | 05:29 PM
nexus6's Avatar
my friend came over today and showed me his setup,he used a fan setup that he took out of an ls1 car and he made a bracket out of aluminum to hold the radiator in place.the good thing is the fans are shrouded and recessed so the ist a clearance issue and they plug into out existing harness without modification.i think im gonna try that.
Old Jun 27, 2004 | 07:02 PM
Engine: 5.8Ltr 356
does that mean that the 1" radiator is a drop in?
Old Jun 27, 2004 | 10:05 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
How much will I need to mod the upper/lower supports?? Mine's coming Tuesday......
Old Jun 27, 2004 | 11:00 PM
It will drop in with a few mods. I took out the rubber supports on top and bottom cuz the rad sits too high to use the plastic rad support on top. I replaced them with tire tubing. Its a tight fit on the sides. You will have to put a few pieces of tubing on the sides to keep it from rubbing on metal. I have pics on the post I did the other day. https://www.thirdgen.org/techbb2/sho...hreadid=247826 Fan will need two washers at each location. Have to cut the rad support up top cuz it wont sit on top of the upper hose opening.
Old Jun 27, 2004 | 11:37 PM
Confuzed1's Avatar
Car: 83Z28 HO
Looks like I'm getting the 1" instead......
Old Jun 28, 2004 | 04:09 PM
Engine: 5.8Ltr 356
thats cool that it practically drops in, but is that radiator practically the same size as an OEM unit?? or is 1" bigger than our OEM 2 core radiators?
Old Aug 11, 2004 | 08:54 PM
Engine: 5.8Ltr 356
Wow these spaz fans are way more powerfull than i expected, how did you guys mount them? the parts stores don't have the mounting things, and i don't wanna resort to zip ties.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Chuck84TA
Jul 15, 2016 09:05 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
Papaginos
Sep 27, 2015 03:29 PM
