Blower Motor keeps running with Engine off.
Old May 8, 2021 | 08:34 PM
Carlos89's Avatar
Car: 1986 Trans Am
Engine: 5.0 LG4 4BBL
Transmission: T5 5-Speed
Yep. I have an 86 LG4 Trans Am 5-Speed and tonight after getting home i turn off the car and my AC keeps blowing in Hi fan speed. I check under the hood and I feel a bunch of air by the blower motor.
I turn the engine back on and I only have Hi fan speed on my AC. Switching to med or low doesn't change anything. It blows Hi.
Its too dark right now to see anything but any tips or advice appreciated. THANK YOU.
Carlos
Old May 8, 2021 | 08:38 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Blower Motor keeps running with Engine off.
Disconnect the battery for now or pull the high speed relay by the blower housing.
Old May 8, 2021 | 09:18 PM
History would help.
How long have you had this car? How long has it done this? Did it just start? Been doing any kind of work on it? ... We can all go 15 rounds of maybe it's this maybe it's that in a vacuum but that's not likely to be much help fixing it.
As said, unhook the batt so that it doesn't run down tonight, and tackle it in the morning with light and a fresh mind. Don't trust to the relay being the culprit.
Old May 8, 2021 | 09:40 PM
Carlos89's Avatar
Car: 1986 Trans Am
That's what I did i disconnected the battery for the night. I've had the car a month or so. No work done because all's been fine up to now. The wiring between the blower motor and from the resistor sure doesn't look OEM but ill check it out and post pics in the morning.
Thanks again guys.
Old May 9, 2021 | 07:11 AM
Carlos89's Avatar
Car: 1986 Trans Am
This morning I got a better look and I removed the hi speed relay and a bunch of black water dripped out and there are signs of overheating.
The connector looks pretty crappy as well
The wiring (if it's factory or not i don't know) looks ok. The resistor and wiring from the resistor also looks fine.
I noticed that if I "wiggle" the connection between the hi speed relay and connector when the issue is present, it goes away. Perhaps a bad connection there caused by the water intrusion? I found the correct hi speed relay online and its on the way but I can't find the connector section at the moment. I'll keep looking.
Old May 9, 2021 | 08:31 AM
Engine: Lb9
Transmission: M20
I’m thinking the relay got stuck
http://www.austinthirdgen.org/mkport...C60_manual.jpg
Old May 9, 2021 | 09:26 AM
Carlos89's Avatar
Car: 1986 Trans Am
Because of all the water that got in perhaps? Thanks for the diagram by the way.
Old May 9, 2021 | 09:39 AM
Engine: Lb9
Transmission: M20
A engine cooling fan relay would be more weatherproof efi connection or tpi parts has them relays have the schematic on top as well.
Old May 9, 2021 | 11:59 AM
That doesn't look right.
The blower high-speed relay should have 5 contacts, not 4.
Neither the connector nor the relay belong there. They're both "factory", just, not for that application.
Also, the wires should be a fat purple, a fat red, a smaller orange, a pink w/black stripe, and a green w/ white stripe. I see most of those colors of wires in there except that somebody has butchered them.
Looks like some sodomy has occurred there, somewhat recently, by someone who put forth a valiant effort but didn't know what they were doing.
I'd suggest a relay and connector about like this. https://www.americanautowire.com/shop/relay-4826 It's waterproof, MUCH better than the original in your car; in fact later cars used one like this instead.
Automotive relays commonly have an inscrutable terminal designation, usually numbers; hook the green/white to 85 or 86 and the pink/black to the other of those, the purple to 30, the fat red to 87 (be careful: it has hard battery on it), and the orange to 87A. Use electronic (NOT plumbing) solder after crimping those connectors on (they don't have to be near as carefully crimped if you do that) with some rosin flux. You can get all that stuff at MicroCenter or places like that.
Old May 10, 2021 | 11:04 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
If you fix the wiring and still have the issue, it could be your ignition switch. This is the switch that is under the dash and mounted on top of the steering column (NOT the key ignition). I have had 2 or 3 of these go bad on different GM vehicles and they allow ignition current to continue flowing even when you shut off the ignition. Each time I have noticed the blower fan will continue running after ignition is turned off. They are cheap and pretty easy to replace.
Old May 10, 2021 | 09:14 PM
Carlos89's Avatar
Car: 1986 Trans Am
Thank you for all the advice. I'll get to work on some reading on repairing the wiring.
Old May 10, 2021 | 09:17 PM
Carlos89's Avatar
Car: 1986 Trans Am
Will check this out. Thanks.
Old May 11, 2021 | 01:15 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
86 Firebird Blower relay only needs 4-contacts........ 5th contact shown as "not used". These diagrams are for the 1986 "manual" ( not digital dash ) Firebird.
Obviously; Since the relay had water in it,... start by replacing that thing !
Old May 11, 2021 | 01:48 PM
Engine: Lb9
Transmission: M20
I knew you had the right schematic
Old May 11, 2021 | 03:42 PM
John in RI's Avatar
I have my moments !!
Old May 11, 2021 | 04:50 PM
You're right, I'm sorry. The coil wire colors I quoted were for the cooling fan relay, not the HVAC one. Brain cramp.
Old May 15, 2021 | 02:12 PM
Carlos89's Avatar
Car: 1986 Trans Am
Quick update: I ordered a relay/plug from americanautowire. It'll take a few days but I received the relay I had ordered originally from amazon. I placed it and the hi speed works again manually and so far no instances of the blower coming on with the car off.
I'll be keeping an eye on it until I get the parts in ordered.
Thanks again for all the help.
CrazyHawaiian
Apr 25, 2017 05:58 PM
Goldenbullet44
Jan 12, 2010 06:37 AM
supaflypriest
Jun 19, 2005 12:10 PM
coach
Sep 26, 2001 05:16 PM
86ZRICHIE
Jun 21, 2001 03:07 AM
