Running a second cooling fan switch
Old May 22, 2021 | 08:36 AM
88m5's Avatar
Hello everyone
I have a 1986 Camaro 5.0 TPI that i had some problems getting the cooling fan to work. Finally fix it buy taking the computer cover off and reseating the prom and that finally sent the ground signal to turn the fan on. My question is i want to install the coolant fan switch that turns on at 185 degrees on the left side of the block using the coolant drain plug location and then tie in the wire to factory wire which turns the fan on. Since this system works by the ECM sending a ground signal to turn the fan on I would be doing the same thing just earlier. Do you think this could damage the ECM by back feeding a ground signal to the ECM also?
Old May 22, 2021 | 11:34 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Running a second cooling fan switch
Can do as you describe or run a second relay and lower fan on off temps by reprogramming the prom.
Old May 22, 2021 | 11:55 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
You could run a more classic setup and bypass the computer
Old Jun 3, 2021 | 04:30 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Is there a location to put a secondary fan switch? Im installing a second fan and wouldnt mind running it off of a secondary fan switch.
Old Jun 3, 2021 | 08:30 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Do you need it to turn on the fan at a different temperature, or at the same time?
Old Jun 3, 2021 | 09:33 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Except that is where the Temp gauge sending unit goes. The fan thermostat goes on the passenger-side cylinder head between #6 & #8.
Also; while the relay will work that way, the "proper" way is to run pin 30 to the + battery terminal with the fuse, and 87 to the + side of the fan...
Old Jun 4, 2021 | 01:05 PM
1989karr's Avatar
Engine: 3.4 / 5.0
For me it'd be at a differetn temp or whatever sensor I would get really lol maybe a bit cooler than the one i got now....
I don;t know of any other place to stick another sender though.
Old Jun 5, 2021 | 07:50 AM
88m5's Avatar
I ended up putting the sender on the left side of the engine block coolant drain plug which is 1/4 NPT so found switch on Amazon.
Old Jul 2, 2021 | 04:41 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Ok I wanted to use a stock easy to get GM fan switch so i got an adapter off of Amazon
Old Jul 29, 2021 | 01:40 AM
Dsac's Avatar
Car: 1984 sportanetta Camaro
Axle/Gears: 372 I think
I have an 84 with a 350 and 700r4 and the only thing hooked up to the ecm is the transmission. I put LS1 fans in and upgraded my alt from 78 to 110 as the fans are a 40 amp draw. I have the relay and fuse and everything set up to the key. It has a temp switch that turns them on at 185 and off at 165 most of the time. Sometimes they don't come on at all and I can't figure out why. The temp switch i put in the top of the thermostat cover could that be it? Should I move it down to the manifold? Is it possible to add a switch so if they don't come on with the temp switch I can manually turn them on?
Old Jul 29, 2021 | 01:24 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Nice! You got a pic? Im planning to do a LS1 fan swap soon and curious to see how you mounted it / cut the shroud etc...
Sounds like the temp switch is possibly bad and not working all the time? or if you put teflon tape on the switch? If you put too much it won't be able to ground properly....Id move it to the manifold for best grounding if possible though.... Are you using 2 separate relays? The Ls1 fans suck lots of juice so if you are using one relay it could be shorting it out,,,that happened to a cheap relay I had for something else..it was burning out and worked intermittently.
I have my auxiliary fan set up on a separate circuit from the OE fan and to come on automatically but I can control it manually as well cause "just in case" and it's super easy..........basically you just put a switch you can ground between the fan and the grounding temp switch you have....just splice into the wire going to your temp switch and have it ground when you flip the switch.
The mnual switch wil lalways turn the fan on......If it doen;t always work with the manual switch then you have some other issue before the switch though.. You;re just putting the manual switch between the relay and PT770 in the other pic on this thread...
Check out this diagram
Relay Wiring Diagram For Dual Fans (wiringdiagramall.blogspot.com)
Old Jul 29, 2021 | 01:31 PM
midias's Avatar
When I first started running dual fans I had issues with a single thermal switch turning on two relays. I ended up installing a helper relay to keep thermal switches from blowing out.
Old Jul 29, 2021 | 09:13 PM
Dsac's Avatar
I only have one relay and its hooked to the key.
I used my drimmel to cut the hold down so the fans fit under it. I also bolted the fans to the bottm of the radiator so it is nice and soild.
Battery power and the ground for the passengers side fan.
I have the temp switch here cause i used where i had it before in the manifold for the heater hose.
Old Jul 30, 2021 | 01:19 PM
1989karr's Avatar
Engine: 3.4 / 5.0
thanks for the pic!!!!!
Hmm, that should ground out ok there.
Your manual switch would wire in between the temp switch and ground ...I grounded mine to the dash frame.
Your wiring looks good...I'm thinking it might be the temp switch is not always grounding out at the proper temp etc...
Old Jul 30, 2021 | 08:13 PM
1989karr's Avatar
Engine: 3.4 / 5.0
what shroud is that BTW? It doesn;t look like the standard F-body one
Old Aug 7, 2021 | 10:28 AM
scfbody's Avatar
Car: 1983 Z28, 1991 Z28 & 1985 TA
This is the easiest way I found to control an electric fan. The small relay has an adjustment to control when the fan comes on and also you can add an over ride switch. Easy to hook up and small. I just eliminated the ecm control and use this set up instead, car runs under 180 degrees during the summer in Texas. I added a switch inside so I can turn on both fans if I want, but so far car stays cool with only one fan running.
Flex-A-Lite Electric Fan Controller (screamingchicken.com)
newRSdriver
May 30, 2007 08:06 AM
89Vert
Aug 9, 2006 06:12 AM
DustyJL
Dec 20, 2004 05:30 PM
bmwtech
Jun 28, 2002 03:54 PM
gonzo350
Mar 12, 2002 03:45 PM
