Coolant leak at Firewall (Not heater core) 85 Z28 383stroker
Old Oct 31, 2021 | 03:50 PM
HeavyChevy383's Avatar
There seems to be a steady coolant leak on my passenger side that runs down or very near the firewall. I know for a fact it's not the heater core since I just replaced it and there's no liquid inside the car and none under the heater core hoses. My question is, what else should I check? And I am certain it is coolant leaking.
also note that I just replaced my headers so it's running on open headers and the car is smoking up after running for 2mins. I believe the coolant has to be hitting the headers and then causing the smoke when the headers warm up. There's no y pipe connected as well. What else could it possibly be?
Old Oct 31, 2021 | 05:12 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Coolant leak at Firewall (Not heater core) 85 Z28 383stroker
Intake manifold gaskets or freeze plugs would be my guess.
Old Nov 2, 2021 | 10:40 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
It could be metal pipe that runs near firewall to radiator(pipe n 2 at picture) https://www.thirdgen.org/forums/atta...osediagram.jpg
Old Nov 3, 2021 | 10:35 AM
NoEmissions84TA's Avatar
Did you reuse the old hose?
Use this type of hose clamp.
You can clearly see why from the pic.
HeavyChevy383
Sep 21, 2021 04:13 PM
Apathy
Jul 8, 2013 06:49 PM
Checkerbelly
Apr 12, 2010 08:26 AM
19Pontiac88
May 12, 2009 05:21 PM
Oldman&theZ
Jul 4, 2003 10:33 PM
