Rad fan switch 5/16 vs 9/16?
Car: 85 t/a
Engine: 5.0 tpi
Broke my radiator fan switch taking off passenger side exhaust manifold of my 85 TA 305 tpi. Mine is the 5/16 unit but RockAuto and other places also list a 9/16 unit (diameter of sensor end that goes into the head) As far as I can tell they'll both thread in. Wondering what the difference is between the 2 sizes because to replace my 5/16 unit is $40... but the 9/16 unit is only $10.
Car: 85 t/a
Engine: 5.0 tpi
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Rad fan switch 5/16 vs 9/16?
Are you referring to the button head size on the switch?
Car: 85 t/a
Engine: 5.0 tpi
Engine: Lb9
Transmission: M20
If the only difference is the tip of the switch diameter and both are 3/8 npt and same button head either should work. Might opt for best quality or get a wells sw555 or equivalent. A single wire spade from summit racing at lower on/off temp is a option as well
Looks to me like the difference is either the height or the size of the part that goes into the water jacket.
The difference is YYYYYYYYYUUUUUUUUUUUUUUJJJJJJJJJJJJE.
5/16" = .3125"
9/16" = .5625"
The tip of both is obviously the same diameter anyway. They use the same connector. The # isn't the dia of that.
Looks to me like you could use either one. The shorter would probably be a better fit, at least would be more out of the way of everything else around it. But it probably doesn't matter in the slightest.
5/16" = .3125"
9/16" = .5625"
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I'd opt for the 5/16 which is what the stock switch looks like....... the 9/16 might impede coolant flow.
