which universal coolant overflow tank?
Old Feb 6, 2023 | 07:44 PM
Blown_WS6's Avatar
Car: 1991 Firebird Formula
I want to get rid of the large and unsightly stock coolant overflow tank and I would like to put one of those aluminum universal ones tucked away somewhere. Anyone have any good installs they have seen or done? Looking for ideas.
Old Feb 8, 2023 | 05:38 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: which universal coolant overflow tank?
The 4th gen tanks are practically invisible aside from the fill. Might want to look into one of those
Old Feb 9, 2023 | 08:11 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
I put one of those in. It was an amazon item but has worked very well.
Old Apr 11, 2023 | 04:53 PM
downsouthboy's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 383 w/ vortec heads
Transmission: WC T-5 w/ SPEC lightweight clutch
thats a clean engine bay. is that the champion 3 row radiator ???
Old Apr 12, 2023 | 09:05 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Yup, thats the Champion 3 row with built in trans cooler
thanks!
Old May 19, 2023 | 11:20 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Updating photo with catch can re-powder coated
Old May 31, 2023 | 11:56 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Fabbed Aluminum tank from Amazon. It had an extra tab so I added a third hole and nutserts.
Old Jun 10, 2023 | 05:34 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Hi Midas. Would you have an item number for the tank you used from Amazon??? Thanks in advance!!!
Old Jun 21, 2023 | 01:06 PM
midias's Avatar
Here it is
Amazon Amazon
Old Jun 22, 2023 | 08:28 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I'm using a billet specialties one that I have bolted into the front rad support. It hides nicely here. Bottom left of image. Not the best pciture.
Sean White
Nov 20, 2021 01:24 PM
joalva91
Jul 13, 2015 07:35 AM
That Sky Guy
May 7, 2015 11:52 AM
RICH92RS350
Jun 22, 2004 12:57 AM
therckid
May 1, 2004 04:12 PM
