A/C Condenser
Old Feb 9, 2023 | 11:29 AM
carlos64030's Avatar
Car: 1991 Trans Am GTA
A/C Condenser
I purchased a brand-new A/C condenser for my 1991 Trans Am GTA a few years ago and left it sitting in the garage. The car is now currently in the shop for an engine swap. The engine swap is being finalized, but turns out the high-side port for that A/C condenser is wrong. The shop tried 3 other A/C condensers from different sources and they were all the same as the one I purchased.
I don't know what's up with that. If you've changed your A/C condenser recently and all of the fittings on it were correct, where did you purchase it from? As of right now, the current plan is to try and weld on the correct fitting which may prove to be difficult since the material is really thin.
Old Feb 9, 2023 | 04:02 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: A/C Condenser
If I recall, the 91-92 cars had different fittings at the condenser end........as well as the 82-84? cars. The condenser wil lfit physically, but the fittings won;t match.
i think they only make 85-90 condensers.although they are listed as 82-92
You can swap parts from the 85-90cars in.,....Im guessing its the line that goes from the evaporator to the condenser, right?
Old Feb 9, 2023 | 10:10 PM
Re: A/C Condenser
I kinda figured the condenser for the '91 - '92 cars were changed for some odd reason. Yes, I'm pretty sure it is the evap line going to the condenser.
Old Feb 10, 2023 | 06:03 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Re: A/C Condenser
This is what I put in my 91 last March. Everything was a good fit.
https://www.partsgeek.com/ss/?ssq=19...%2FC+Condenser
Old Feb 10, 2023 | 12:08 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Re: A/C Condenser
Maybe t was 92... but ytu could have a later production 91 that has the 92 fittings.
Old Jun 6, 2024 | 08:43 AM
PAformula's Avatar
Re: A/C Condenser
Your link brings up multiple p/n's. Can you list the exact p/n you used?
thanks!
Old Jun 6, 2024 | 11:20 AM
BBCSwap's Avatar
Re: A/C Condenser
I don't think any of those are the one I used. It looks like they changed brands. I don't know for sure. I can't find any of my previous orders.
Old Jun 11, 2024 | 10:05 AM
PAformula's Avatar
Re: A/C Condenser
So I ordered a OSC 3231 condenser off of Rock auto. It came in with angles welded to the top of each corner that don't show up in pictures. Anyone else run into this? Going to try it tonight. 10 days away from a big show, no time to reorder another.
Old Jun 11, 2024 | 11:18 AM
BBCSwap's Avatar
Re: A/C Condenser
Mine was the same way. I filed the sharp edges so it didn't cut into the rubber mounts.
Old Jun 11, 2024 | 04:27 PM
PAformula's Avatar
Re: A/C Condenser
Are these fittings supposed to spin freely or the hard lines from evap and compresser?
Old Jun 11, 2024 | 04:49 PM
BBCSwap's Avatar
Re: A/C Condenser
The fittings on the lines turn.
Old Jun 11, 2024 | 04:50 PM
PAformula's Avatar
Re: A/C Condenser
Just making sure, my lines are seized. Fun fun. Thanks!
Old Jun 17, 2024 | 02:10 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: A/C Condenser
A little heat and penetrating lube.
Firechicken86
Oct 15, 2012 06:17 AM
jaweiss
Jul 9, 2011 08:45 AM
Goumba T
Jun 1, 2005 05:16 PM
92 Formula
Mid-Atlantic Region
Apr 1, 2002 03:48 PM
