My 95 350 TBI Rad Issue
Old Jul 10, 2023 | 12:28 PM
GBousley's Avatar
Car: 1992 Firebird base
Engine: 305 TBI
Transmission: 700r4 / 4l60
Axle/Gears: stock
I hope you don't mind me asking a question regarding my '95 Chevy G20 Van, as there's a lot of overlap between that and my 3rd gen.
It's a 350 TBI, stock radiator setup. I replaced my cracked radiator with a stock replacement and AFTERWARD noticed that the small valve right under the cap that feeds to the overflow reservoir was snapped off. Either I did it in transit, or it came that way, no idea.
This radiator came with a plastic outlet just below that broken nozzle that I think is for a different application, because the Rad came with a delete cap for that valve and I have no hose for it in my application.
So, I decided to get a hose to fit that outlet and run it to the reservoir instead. As for the broken nozzle, I JB welded and wrapped it closed.
My question is, anyone with experience can vouch for this set up working (where I placed the hose to the reservoir)? Any issues? Also, should I just cap that outlet and delete the reservoir?
Here's an image of the old Rad nozzle that broke off on the new one, followed by the new rad and hose setup going to the reservoir.
Old Jul 10, 2023 | 12:30 PM
GBousley's Avatar
Engine: 305 TBI
Axle/Gears: stock
Re: My 95 350 TBI Rad Issue
Wanted to add, this is a temporary setup to keep driving the vehicle until I can order a new non-damaged radiator. I do plan to drive the van maybe 100 miles or so this way in the upcoming weeks.
Old Jul 10, 2023 | 01:01 PM
GBousley's Avatar
Engine: 305 TBI
Axle/Gears: stock
So, thinking more about the hose attached to that outlet (seen in the 2nd pic in OP and new pic attached here), It appears to be BELOW the cap seal, where as the intended reservoir outlet is above where the cap seals inside the neck. My intuition is telling me that this setup will not work, as the system will try to pressurize the reservoir, correct? Which, I don't think is meant to be pressurized.
Old Jul 10, 2023 | 07:14 PM
GBousley's Avatar
Engine: 305 TBI
Axle/Gears: stock
UPDATE: Put the old rad back in. That fix wasn't a great idea and glad I didn't drive it that way. The old rad had a small crack that I JB Welded months ago and hadn't leaked since. It's in better shape than the new rad. Will reorder another rad..
stevek
May 8, 2010 01:11 PM
mbrownone
Sep 9, 2006 12:04 AM
steve87iroc
Jun 10, 2006 10:46 PM
Scott_92RS
Sep 1, 2004 02:30 PM
9D1maroRStoner
Feb 23, 2004 07:11 AM
