Electric Fan doesn’t start when reaches temp
Old Mar 29, 2024 | 03:36 PM
Dawkid01's Avatar
I’m having an issue with my electric fan. If I turn the AC on the fan will come on but it won’t engage when it comes to temp.
I have new thermostat
new sender (although I thinks this only does the gauge)
thoughts from the group?
Old Mar 29, 2024 | 03:51 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Electric Fan doesn’t start when reaches temp
Application? A single fan tbi or v6 ? Have you grounded the temp switch ?
Old Mar 29, 2024 | 03:58 PM
Dawkid01's Avatar
Sorry V8 TBI
Old Mar 29, 2024 | 04:02 PM
Engine: Lb9
Transmission: M20
Originally Posted by Dawkid01
Sorry V8 TBI
what happens when you ground the cylinder head temp switch located on the passenger cylinder head ?
Old Mar 29, 2024 | 04:07 PM
Actually, ground the wire that goes to the switch, not the switch itself. Those pesky details.
Old Mar 29, 2024 | 04:14 PM
Engine: Lb9
Transmission: M20
yes I should of elaborated on that, thanks
Old Apr 2, 2024 | 12:25 PM
Dawkid01's Avatar
Sorry for the delay, pesky work had me tied up.
Which of the wires is ground?
Old Apr 2, 2024 | 12:28 PM
Engine: Lb9
Transmission: M20
The engine block is ground
Old Apr 2, 2024 | 12:50 PM
Dawkid01's Avatar
The wire going to the fan sensor in the block is blue...
Do I ground that wire blue? Does that complete the circuit for the fan to turn on?
Old Apr 2, 2024 | 12:58 PM
Engine: Lb9
Transmission: M20
Should be wired like this, this shows a green/white to cylinder head temp switch. Could ground at the relay to test the relay. The knock sensor lead could of been swapped if it’s a blue wire.
https://austinthirdgen.org/storage/d...an_V8_vinE.jpg
Old Apr 2, 2024 | 01:02 PM
Engine: Lb9
Transmission: M20
https://austinthirdgen.org/storage/d...rk_control.jpg
you never said your year but this shows ks as blue
Old Apr 2, 2024 | 01:22 PM
Dawkid01's Avatar
Sorry, this is a 1991 RS V8 305
Old Apr 2, 2024 | 02:03 PM
Dawkid01's Avatar
This is for spark control, I'm not seeing the connection
Old Apr 2, 2024 | 02:05 PM
Engine: Lb9
Transmission: M20
just saying the ks and temp switch could be swapped
Old Apr 2, 2024 | 02:56 PM
Yup, sounds like you have some connectors plugged onto the wrong things.
The fan switch wire is dk grn w/ wht stripe. Blue is probably the knock sensor. They are the same connector type and are physically close together, therefore easily plug onto the wrong device.
Old Apr 6, 2024 | 08:36 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The stock GM fan switch does not enable the fans until around 220F.
Old Apr 16, 2024 | 06:45 AM
Dawkid01's Avatar
I fixed the issue with the wires (green/white is now on the correct sensor) and replaced the fan sensor and the fan still doesn't engage unless the A/C is turned on. I've let the temp get up to 240 before shutting it down. Any other suggestions?
thanks for your help
Old Apr 16, 2024 | 09:44 AM
Engine: Lb9
Transmission: M20
sensor as in coolant temperature? Or cylinder head temp switch ?
Old Apr 16, 2024 | 11:19 AM
Dawkid01's Avatar
Head unit
Old Apr 16, 2024 | 02:01 PM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
This is what I used to fix that problem, from Hawk's. Even the OEM replacement switches have been known not to turn on until over 240 in some instances. Before I installed this I had just grounded the green/white lead. I figured it was better for the fan to run all the time than wait until it over heated to kick on.
Old Apr 16, 2024 | 03:10 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Chances are the switch is coming on at the right temp but the temp gauge is showing the wrong value. If you want a lower one get a 1989 turbo trans am switch 210 on 195 off.
Old Apr 16, 2024 | 03:42 PM
Engine: Lb9
Transmission: M20
wells sw555 can remove the old temp sw put in in some water on the stove with a vom hooked up and thermometer in the water see if you can get it to close. You would see continuity from center to body.
88ragtop
Jul 11, 2009 06:58 PM
thebird91
Apr 8, 2008 08:36 PM
dankhound
May 12, 2004 06:10 AM
kaupca
May 9, 2004 05:41 AM
86bird_28v6_5spd_ramair
Mar 19, 2002 11:28 PM
