Cooling Replacements
Old Mar 3, 2025 | 04:28 AM
George_Roel's Avatar
Car: 1991 Camaro RS
Engine: 5.7L L98
I am currently rebuilding a 1991 RS and am swapping in the L98 350. I plan to put the ZZ4 cam in the motor. I was wondering what cooling options are viable now? Is it worth upgrading to the fancy expensive radiators or just doing some type of OEM single core style radiator? I can also likely clean up the stock fan and shroud and run that, as it does not seem upgrading gains much cooling with a relatively stock motor.
I was looking at this radiator from Advanced Auto: https://shop.advanceautoparts.com/p/...hTerm=radiator
What other items should I look into, such as thermostats and lower temperature fan switches?
Old Mar 3, 2025 | 06:59 AM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: Cooling Replacements
I had a zz4 in my car w a stock v8 radiator for years and had no over heating issues. A zz4 uses the same aluminum vette heads and has 10:1 comp. IDK what the L98 compression is but I'm sure it's not over 10:1. As long as your cooling sys is good, you're all set. It should be a pretty good setup. You may not make full top end potential w the tpi vs modern intake/efi but I bet the torque will be pretty good. I bet your only hurdle will be tuning. There are people here who can help w that.
Old Mar 3, 2025 | 07:08 AM
Car: 1991 Camaro RS
Engine: 5.7L L98
Yeah I am dreading when I have to get into tuning. That’s a ways down the road and I’m hoping somewhere around me knows how to do it if not I guess I’ll have to learn.
Old Mar 3, 2025 | 03:07 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Both my friend and I got this from rock auto its two row and works great. Then get a 180 thermostat and 89 turbo trans am fan switch
Old Mar 5, 2025 | 05:25 AM
Car: 1991 Camaro RS
Engine: 5.7L L98
Did you reuse the stock fan or did you guys replace that?
Old Mar 5, 2025 | 11:22 AM
midias's Avatar
My friend is running the factory fan with a 89 Turbo TA fan switch I am running a corolla dual fan
https://www.thirdgen.org/forums/cool...n-upgrade.html
TheMagikMan
Jul 22, 2023 11:55 AM
8587ta
Nov 16, 2016 04:29 PM
Jesse Salinas
May 26, 2016 05:41 AM
LilJayV10
Sep 29, 2007 06:40 PM
