Cooling fan switch
Old Apr 15, 2025 | 12:40 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Cooling fan switch
Hey gang anyone know the part number or where to get a lower temp fan switch. I’m talking about the brass sender that goes in the passenger head in between the back two cylinders. It has a round black plastic connector on it like a knock sensor. I need around 180-190 degrees. Thanks.
Old Apr 15, 2025 | 12:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Cooling fan switch
Iirc it’s 3/8 npt , search summit racing for a temp switch. They have a lot of different ones with different on/offs.
Old Apr 15, 2025 | 04:04 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
SW555
Old Apr 15, 2025 | 04:07 PM
Engine: Lb9
Transmission: M20
Iirc that’s 210f on
Old Apr 16, 2025 | 03:33 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Summit sells one that fits that is 180. Although that seems way too low for a fan turn on
Old Apr 21, 2025 | 05:25 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I'm giving this unit a try. Not sure if it will do everything I want it to, but we'll find out.
https://www.thirdgen.org/forums/memb...ml#post6559571
Old Apr 22, 2025 | 12:13 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Isn't that just a temp sender for the dash gauge????
for you guys wondering what fan turn on times are, here are mine, which are factory. https://www.thirdgen.org/forums/cool...ns.html?nojs=1
Old Apr 22, 2025 | 07:16 PM
DynoDave43's Avatar
On my car (L03) that switch controls the cooling fan.
Old Apr 22, 2025 | 08:04 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
If you go to an auto parts store that has paper books still, you can go through them, all the specs and pick virtually any size/thread, on and off temp that you want. I did that decades ago for my car, I used an on at 190, off at 180 for the low speed, then another switch that was on at 210, off at ....something lower....for the fan's hi speed. All with a 160 stat, it worked pretty great, for me.
Old Apr 22, 2025 | 09:08 PM
bennettcvcu's Avatar
Car: 1988 IROC-Z
Engine: L03 to L05: 350 TBI
Transmission: MD8: 700R4
Axle/Gears: GU2: 10 bolt/2.73
Has anyone every used this one/brand? For $60 you'd think it be the last ever fan control switch. Thoughts? I run around 174ºF at steady state so this would be a great for on/off temperatures I need.
Cooling Components P-195 Cooling Components Temperature Sensors | Summit Racing
Rgiambattista
Nov 14, 2021 03:49 PM
zacharyhorn
Dec 22, 2011 04:12 PM
xX89RSXx
May 6, 2010 09:41 PM
CrazyRob75
Nov 9, 2003 02:02 AM
Matty377
May 14, 2003 01:32 PM
