Need pigtail for connector on passenger side cylinder head. Help.
Old Dec 22, 2011 | 08:10 AM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
I can't seem to find the pigtail connector for the sensor on my passenger side cylinder head. I believe it's for either the fan or the temp gauge. Anyone know where I can get this pigtail? Mine's charred. I need this soon.
Thanks,
Old Dec 22, 2011 | 08:34 AM
Car: 91 Firebird
Engine: Turbo 355
Re: Need pigtail for connector on passenger side cylinder head. Help.
Another question on this. I believe it might be the fan switch. (Passenger side between #6 & #8) Do I even need this? My fan is wired to a toggle switch in the cab. My buddy wired it years ago when I went carb. I don't have the computer in the car. So, do I really even need this switch / sensor? Or can I just get a plug?
Old Dec 22, 2011 | 08:44 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The pigtail should be available from TPI Parts, it's for the fan switch.
Why not wire the fan switch back up in tandem with your toggle switch? That way the fan switch will still turn on the fan when you, or some other driver, forgets. If you're running the fan all the time off that toggle you're putting a strain on your electrical system too.
Old Dec 22, 2011 | 09:06 AM
Car: 91 Firebird
Engine: Turbo 355
I don't have a computer anymore. So is the fan switch still useable? If so, how do I wire it to my switch that's in the car now?
Old Dec 22, 2011 | 01:09 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Switch will work without a computer because all it does is ground the wire when it reaches the required temp.
Standard Motor Products part #S550 is the connector, you should be able to get it from any local auto parts store:
http://eaccess.smpcorp.com/eCatalogs...952&Part=S-550
Old Dec 22, 2011 | 01:19 PM
Car: 91 Firebird
Engine: Turbo 355
That's not it. That looks like it would be for the temp gauge sensor on the drivers side. I need the passanger side pigtail. It plugs into the atual fan switch. I'm just confused how to hook it up. There are two wires coming off the pig tail and one green wire going back to the relay.
Old Dec 22, 2011 | 02:50 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
The connector I listed is correct for the fan switch on a 91 Formula 350. If you have a switch in the passengers side head that has more than one wire, the switch is not stock.
Old Dec 22, 2011 | 04:12 PM
naf's Avatar
naf
aftermarket switches had a two wire connector. The second connector is for a ground that the stock switch gets thru its connection to the head at the threads. If you have a two wire switch, connect either lead to ground and the other to the relay lead. Let it idle and warm up, the temp switch should engage the fan when it reaches its setpoint.
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Cameeeero
Aug 20, 2015 03:06 AM
Street Lethal
Aug 14, 2015 08:25 PM
Randomtask2
Aug 13, 2015 01:57 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
