1992 Camaro RS 305 (cooling issues)
Old Aug 11, 2025 | 05:39 PM
thirdgenguy1992's Avatar
I have a 180 thermostat, the stock radiator, the fan is wired to the ignition to always be on, the transmission is separate from the main cooling system, (has its own cooler now) but the car still skyrockets to 220-240,
And even sometimes goes to 250, but after shutting the car off there is zero gurgle or bubbling. it has a new thermostat and the radiator is not clogged. Any ideas how to fix this?
Old Aug 11, 2025 | 05:52 PM
Re: 1992 Camaro RS 305 (cooling issues)
New temperature gauge sending unit
Old Aug 11, 2025 | 07:03 PM
already put a new one in, still the same temperature
Old Aug 11, 2025 | 07:07 PM
bennettcvcu's Avatar
Car: 1988 IROC-Z
Engine: L03 to L05: 350 TBI
Transmission: MD8: 700R4
Axle/Gears: GU2: 10 bolt/2.73
Does it cool okay above 35mph and is only an issue at idle?
Assuming you recently cracked open the system? If so, it may be air-locked. Try parking on an incline, both with the front pointing up and down. Try compressing the upper radiator hose while at temp and cold in both directions.
The other thing that comes to mind is do you have ALL the factory air deflectors installed to include the foam bits? If any of this is missing it may be a situation where the cooling air is being bypassed.
Lastly, but probably not a big worry, is the hood’s cowl seal. This too helps direct airflow where it needs to go.
Cheers,
Chris
Old Aug 12, 2025 | 07:52 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Is the factory air dam in place and undamaged?
Are there any "modifications" to the factory cooling system?
The factory temp gauge is notoriously inaccurate, and only good for relative readings. Obtain an IR temp gun (HF sells one for about $25) and see if the engine is actually getting that hot before you do anything else.
Old Aug 12, 2025 | 08:47 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
I agree with ironwill. "Obtain an IR temp gun" I have one & have used it to check the engine temp at the thermostat housing (180-185). Never had a heating problem
with my 1984 Trans AM.
Old Aug 12, 2025 | 10:13 AM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
i have a byscane, well its a customers, and have been fighting an OH issue.
I removed his autometer guage and installed a cheap oreylies guage, ran it up over the cowl and placed it on the side of the dash.
never been over 190. But the autometer gauge shows 220-230.
You have to check and verify the temp gauge works propely.
Old Aug 12, 2025 | 01:26 PM
What does your IR temp gun say?
Old Aug 12, 2025 | 05:51 PM
still goes to 220-240 when driving.
Old Aug 12, 2025 | 07:00 PM
According to your IR gun?
Old Aug 13, 2025 | 08:21 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Did you change the rad cap? might not be holding proper pressure.
Old Aug 17, 2025 | 03:50 AM
MARTIAN91's Avatar
Car: Z28
I had similar issues. After replacing every part that aids in cooling I decided to purchase BeCool fans even though my fans turned on. The new fans solved my high temp issues. See below link.
https://www.thirdgen.org/forums/cool...-car-have.html
Old Aug 19, 2025 | 06:48 PM
alright guys i have bought a temp gun, made sure the car went up to 220 on the gauge, and i checked radiator, then the radiator cap, heater hoses and the thermostat, all was reading 160-190 range, most likely still gonna get a new radiator and a new temperature gauge.
crystalweig
Apr 25, 2017 04:56 PM
FLYNLOW92rs
Mar 11, 2013 10:28 AM
VelocitySc0pez
May 20, 2011 05:24 PM
jwoodworth90
May 12, 2011 06:21 PM
1Bad3rdGen
May 21, 2006 08:33 PM
