Should a 7730 ECM run w/o an O2 input?
Old May 12, 2002 | 10:01 PM
92RSB4C's Avatar
The car just died on the freeway like I turned it off or something. I've had troubles with it before and it is doing the exact same thing. Also, with the O2 sensor disconnected, what should the voltage from the ECM be? W/o an O2 reading, the car wont even start, not even when it's cold and in open loop.
Old May 13, 2002 | 07:47 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Re: Should a 7730 ECM run w/o an O2 input?
The O2 sensor puts out a voltage of 451 mV until it has warmed up. If the car just died and it won't start, I'd look at something else other than the O2 sensor. Check your fuses carefully.
Old May 13, 2002 | 10:53 AM
92RSB4C's Avatar
Re: Re: Should a 7730 ECM run w/o an O2 input?
Exactly what fuses are you talking about?
Old May 13, 2002 | 01:51 PM
Engine: 385 HSR
Re: Re: Re: Should a 7730 ECM run w/o an O2 input?
The ECM and injector fuses.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
cheesehomer
Dec 31, 2015 08:48 AM
Linson
Oct 1, 2015 09:50 PM
customblackbird
Oct 1, 2015 04:30 PM
Kingchevy
Carburetors
Sep 17, 2015 12:09 PM
