Throttle body and IAC questions
Old Jun 28, 2002 | 03:22 AM
Spifz's Avatar
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
Force EFI link
Ok, if anyone has a moment to browse the above link, at the top there is a 1000 CFM throttle body. Is that black thing on the right side the idle air control motor or something?
What does it do? My best guess is that it can open and close a little bit, possibly like a needle valve to let a bit more or less flow through the throttle body at the computers control.
Old Jun 28, 2002 | 06:34 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
That would be my only guess.
Old Jun 28, 2002 | 12:17 PM
Spifz's Avatar
Now I wonder what I have to build to use an IAC in my own throttle body? Maybe a passage from before the throttle plates to after the plates with this little device blocking the passage somehow. I guess I should just buy one (the IAC, not the $525 1000 cfm throttle body...)
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
