Chip? (sorry its kinda long)
Old Oct 16, 2002 | 02:52 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
I have a 1986 Trans Am that had an LB9 305 TPI with the 700R4 tranny. I recently put in a 350 TPI with a mild cam and 21lb fuel injectors. Every place i have called (pontiac dealers, jetchip, honest performance, and a place that does custom chips) all said that i need a custom chip. The pontiac dealer said that he does't know wich stock replacemet chip i would need so he said it would be best to go with a custom one. Jet Chip said that their chip is just an ad-on and i need a custom one to make it run right. I guess thats why my milage sucks, the tranny doesn't kick down from overdrive to passing gear when stomped on, and just lack of power. I should have 275HP but it doesn't feel like it. The engine i put in was a "New Rebuilt". It has around 500 miles on it now. Any ideas? The custom chip is going to cost me $600 and i dont want to spend that if i dont have too. Thanks in advance!
Old Oct 18, 2002 | 04:31 PM
Anybody?
Old Oct 21, 2002 | 12:41 AM
IROCFAST's Avatar
I have a good friend that runs a 10:1 355 with edelbrock heads, stealth ram intake, SLP cam (224/230 @ .50 .502/.510 lift) headers, no emmisions, cold air intake and the list of mods goes on and on. All it has is a jet chip in it. I think the MAF cars are much more forgiving than people think...because his car (and mine before I built the current carb'd setup) idle and drive fine. His car has went 12.3 @ 113...sounds pretty good to me!
Old Oct 21, 2002 | 11:30 PM
Why would 95% of the people i talk to even Jet Performance and the pontiac dealers say that i need a custom chip? They say the ECM is the same but the Chip (EPROM) is different even on an MAF car. I really confused need to find out what is really going on. When i start it up (cold) it doesn't go to its cold start mode, the RPM's go up and down between 500 and 850. Everything i have said to everyone seems to lead back to the chip. What do you guys think i should do? Thanks!
Old Oct 25, 2002 | 11:02 AM
funstick's Avatar
for optimum performance and economy as well as emisions you should get a custom chip. other than that if your happy with it performing at less than its best stick with what youve got. ooh and bruning your own proms is fun and can be alot cheaper than a custom chip.
check here for a programmer.
www.ustr.net
go here for ECM hardware and scannign sofwtare
www.moates.net
goto
www.akmcables.com for a good diagnostic cable
goto www.tunercat.com for sowftare to edit the chip you can burn and replace with al of the above mentioned links.
btw if you car ir realy and 87 the program id byte could be either a $32 $32b so you will need to find this out first. email tunercat they should be able to help you for sure. or if ydont want to undertake tunning your own eproms get out teh phone book and ask around. competent tuners are hard to find.
Old Oct 25, 2002 | 01:15 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
What your not offering your services?
Old Oct 25, 2002 | 02:19 PM
funstick's Avatar
satrun i cant hes nto a local. secondly i dont advertise on the thrigen.org web board. i dont advertise on the diy-efi mailing list. i dont advertise over at the gmecm website either. in fact i respect and do not solicit anybody for sale here. if your a memeber of the thirgen.org community and you ask for my help i will freely give it. inculding but not limited to the use of my euqipment. i dont know i have some nice stuff. 2 laptops, programmer, emulator, communications software, cables,if your a memeber of thigrdgen.org and ask for my help i gladly give it. as for my other business dealings they all come through speed shops and sevral local shops. i do not solicit business here.
Old Oct 28, 2002 | 08:59 PM
I talked to a high performance mechanic and he said that i should get a new ECM from a 87 GTA with the 5.7 TPI auto with over drive from a wrecking yard and then put in a Hypertech chip. What Hypertech chip would i need with a mild cam and a 180* thermostat? On hypertech's webpage they said the street runner is for stock vehicals using the stock thermostat. So i would need the "Thermo Master" chip?
I talked to a high performance mechanic and he said that i should get a new ECM from a 87 GTA with the 5.7 TPI auto with over drive from a wrecking yard and then put in a Hypertech chip. What Hypertech chip would i need with a mild cam and a 180* (not the 195* like i thought i had) thermostat? On hypertech's webpage they said the street runner is for stock vehicals using the stock thermostat. So i would need the "Thermo Master" chip?
db057
Apr 28, 2019 07:45 AM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
rudolphschenker
Sep 4, 2015 02:41 AM
